Fortran What Is the Meaning of This Fortran Error Message?
  • Thread starter Thread starter selmayda
    Fortran Program
The discussion centers around an error encountered while running a Fortran program. The error message indicates issues with the use of the `float` function and the concatenation of write statements. It suggests that the calculation of `float(accept) / (accept + reject)` should be assigned to a variable before being printed, rather than being included directly in the write statement. Additionally, it emphasizes the importance of proper line continuation in Fortran, recommending that each write statement be on its own line or use the continuation character to avoid syntax errors. The overall focus is on resolving the coding errors to ensure successful execution of the program.
selmayda
Hi;
I am trying to run a program which includes;
call AB
write(6,*) 'finished AB'
c---------
call ABp(Vup,gup)
call ABp(Vdn,gdn)
write(6,*) 'finished ABp'
c------------------------------------------------------------------
c do warmup sweeps
c-----
accept = 1
reject = 0
do 410 i = 1, iwarm
call sweep(i)
if (mod(i,10).eq.0) then
write(6,*) 'warmup sweep = ',i
endif
410 continue
write(6, *) 'after warmups, accept ratio = ',
1 float( accept ) / (accept+reject)
write(46,*)
write(46,*) 'after warmups, accept ratio = ',
1 float(accept)/(accept+reject)
c--------------------------------------------------------------------------
but I see an error message ;
multi0.f: In program `multi':
multi0.f:97:
write(6,*) 'accept ratio ='
multi0.f:98: (continued):
1 float(accept) / (accept+reject)
Invalid radix specifier `float' at (2) for typeless constant at (1)
multi0.f:98:
1 2
Concatenation operator at (1) must operate on two subexpressions of character type, but the subexpression at (2) is not of character type
mv: cannot stat `a.out': No such file or directory
what is the meaning of this message?
thanks.
Technology news on Phys.org
It would be helpful to see the entire program.
You may want to make your calculation of float(accept)/(accept+reject) previous to the write statement, assign the results to a single variable and print out such variable without any typecasting or anything.
I'm reasoably sure that the errors are cause by these lines of code:
Code:
1 float( accept ) / (accept+reject)[/color]
write(46,*)
1 float(accept)/(accept+reject)[/color]
Fortran is very picky about splitting lines of code. Either put each write statement on its own line for the entire statement, or use the continuation character, & or +.
Thread 'Is this public key encryption?'
I've tried to intuit public key encryption but never quite managed. But this seems to wrap it up in a bow. This seems to be a very elegant way of transmitting a message publicly that only the sender and receiver can decipher. Is this how PKE works? No, it cant be. In the above case, the requester knows the target's "secret" key - because they have his ID, and therefore knows his birthdate.
I tried a web search "the loss of programming ", and found an article saying that all aspects of writing, developing, and testing software programs will one day all be handled through artificial intelligence. One must wonder then, who is responsible. WHO is responsible for any problems, bugs, deficiencies, or whatever malfunctions which the programs make their users endure? Things may work wrong however the "wrong" happens. AI needs to fix the problems for the users. Any way to...
