Find slope of line, two points on the line are included
To find the slope of the line through the points (-16, -1) and (-17, -7), the correct formula is m = (y2 - y1) / (x2 - x1). The initial calculation of 3/8 was incorrect due to a substitution error. After reviewing the work, the correct slope (m) was determined to be 6, with the y-intercept (b) calculated as 95 using the point-slope formula. The discussion highlights the importance of careful substitution and verification in slope calculations.
rcmango
find the slope of this line it contains these points:
(-16, -1) , (-17, -7)
y = mx + b
i got y = 3/8x - .625
is that correct?
my work i use -7 +1 / -17 + 1
==-6/16
==6/16 = 3/8
then i used -7 = 3/8 * -17 + b
=6.375
y = mx + b
is that correct?
==-6/16
==6/16 = 3/8
=6.375
Not quite, you got the gradient wrong. In the formula
m=\frac{y_2-y_1}{x_2-x_1}
You mistakenly substituted y1 a second time where x1 is instead meant to be.
Also, your technique to find the missing value of b works, but you might also be interested to know that there is a formula for a line that has gradient m and passes through the point (x0,y0) as
y-y_0=m(x-x_0)
And if we divide both sides by x-x0, you may see it is quite similar to the gradient formula:
m=\frac{y-y_0}{x-x_0}
thankyou upon checking my work, i got the m = 6
and the b = 95
and I also used the new point slope formula, thanks.
I tried to combine those 2 formulas but it didn't work. I tried using another case where there are 2 red balls and 2 blue balls only so when combining the formula I got ##\frac{(4-1)!}{2!2!}=\frac{3}{2}## which does not make sense. Is there any formula to calculate cyclic permutation of identical objects or I have to do it by listing all the possibilities? Thanks
