What's the difference between apparent horizon and event horizon?
xuphys
What's the difference between apparent horizon and event horizon? I checked Wikipedia but I still don't understand. Could anyone give a short explanation?
Thanks!
The apparent horizon is, roughly speaking, the surface at which light rays shined radially outward do not move radially outward (inside the apparent horizon, they move inwards.) This implies that the apparent horizon is a local concept, in the sense that it relies only on an experiment in some small region of spacetime. Furthermore, apparent horizons are coordinate dependent horizons which can change or even vanish depending on your slicing of spacetime.
Event horizons, by contrast, are the surfaces beyond which light can never propagate to null infinity. This definition requires you to know the entire history of the spacetime to determine whether or not the light can escape, and in this sense it is a fundamental causal property of the spacetime which does not depend on coordinates.
Other differences between the two are that apparent horizons, if they exist, are always inside event horizons. The two horizons also coincide for a static spacetime. The apparent horizon can evolve discontinuously, while the EH evolves smoothly.
Thank you for responding. Do you know about dynamical apparent horizon? It seems related to cosmological event horizon. I am wondering whether the dynamical apparent horizon is the same thing with what you mentioned here...
Thank you again!
OK, so this has bugged me for a while about the equivalence principle and the black hole information paradox. If black holes "evaporate" via Hawking radiation, then they cannot exist forever. So, from my external perspective, watching the person fall in, they slow down, freeze, and redshift to "nothing," but never cross the event horizon. Does the equivalence principle say my perspective is valid? If it does, is it possible that that person really never crossed the event horizon? The...
In this video I can see a person walking around lines of curvature on a sphere with an arrow strapped to his waist. His task is to keep the arrow pointed in the same direction How does he do this ? Does he use a reference point like the stars? (that only move very slowly) If that is how he keeps the arrow pointing in the same direction, is that equivalent to saying that he orients the arrow wrt the 3d space that the sphere is embedded in? So ,although one refers to intrinsic curvature...
So, to calculate a proper time of a worldline in SR using an inertial frame is quite easy. But I struggled a bit using a "rotating frame metric" and now I'm not sure whether I'll do it right. Couls someone point me in the right direction? "What have you tried?" Well, trying to help truly absolute layppl with some variation of a "Circular Twin Paradox" not using an inertial frame of reference for whatevere reason. I thought it would be a bit of a challenge so I made a derivation or...
