Challenging Hypotheses: The Role of Disproving in Scientific Research
  • Thread starter Thread starter Ardit
In scientific research, disproving a hypothesis is a normal and valuable outcome, even if it diverges from initial expectations. If evidence shows that the hypothesis is incorrect, it can lead to significant insights, although it may risk funding if the research direction changes. Starting with a broad hypothesis can be unusual, as researchers typically focus on specific relationships. The process of testing often reveals that disproving the null hypothesis is more about failing to find evidence rather than outright proving it. Overall, the likelihood of unexpected results is high, emphasizing the importance of adaptability in research.
Ardit
Let's say we do a research whose hypothesis is "X is related to Y".
Also, similar studies are supporting this hypothesis.
Therefore the null hypothesis is going to be "X is not related to Y".
So, the research objective is to prove that the null hypothesis is wrong.
But during my research, the things went in such a way that I was able to prove and find evidences that the hypothesis is actually wrong.
Is this normal? Does it cause any problem with the research structure?
Is this normal?
Yes.
No. Well... if a hypothesis fails to pan out early in the research you may find your funding dropped ... you have to find something else to go on with. Does that count as "a problem with the research structure"? If it was generally thought that there was a relationship between X and Y and you can provide evidence that there isn't one, though, that is a promising career right there.
What's unusual is starting out with such a general proposition - usually you are interested in a particular relationship (unless you are just exploring and observing phenomena). But there are lots of things that look like they may be related to each other but turn out not to have any special relationship after all.
Note that the test to disprove the null hypothesis seldom ends up proving it - the test just ends up failing to provide enough evidence to disprove it.
In general - there are far more ways of being wrong than there are of being right so the smart money is on the experiment/research not going the way you expect.
Thread 'Is there a white hole inside every black hole?'
This is what I am thinking. How much feasible is it? There is a white hole inside every black hole The white hole spits mass/energy out continuously The mass/energy that is spit out of a white hole drops back into it eventually. This is because of extreme space time curvature around the white hole Ironically this extreme space time curvature of the space around a white hole is caused by the huge mass/energy packed in the white hole Because of continuously spitting mass/energy which keeps...
