Another arithmetic progression problem
The problem involves finding the sum of the first 15 terms of an arithmetic progression (AP) where the sum of the first three terms is 30 and the sum of their squares is 692. The correct approach reveals that the first term (a1) is -4 and the common difference (d) is 14, leading to a sequence of -4, 10, and 24. The sum of the first 15 terms is calculated to be 1410. There is confusion regarding the textbook's assertion that the first term is 10, which is incorrect, as it refers to the second term of the progression.
Government$
Sum of first three members of increasing arithmetic progression is 30 and sum of their squares is 692. What is the sum of the first 15 members?
So i have system of equations:
a1 + a2 + a3 = 30
(a1)^2 + (a2^2) + (a3^2) = 692
3a1 + 3d = 30
3(a1)^2 +6(a2)d + d^2= 691
d = 10 - a1
and if i plug that in 3(a1)^2 +6(a2)d + d^2= 691 i get
2(a1)^2 - 40a1 -192 = 0
now when i find roots of this equation i get 24 and -4 none of them are correct since it says that at the end of the book that a1 = 10 and d=14. Now i do get d=14 with a1=-4 d=-14 with a=-24 but since it is increasing progression i can rule out d=-14, but apparently my solution is not correct. And my solutions satisfy equation 3a1 + 3d = 30 while theirs doesnt.
P.S. This is how they solved this problem:
let a2=a then we get
3a=30 and 3a^2 + 2d^2=692 from that we get a1=10 and d=14 so S15 = 1410
thank you
a1 + a2 + a3 = 30
Neither of these equations uses the fact that this is an arithmetic progression
3a1 + 3d = 30
I think you are trying to use it here but are doing it incorrectly. Starting from a1 the numbers are a1, a1+ d and a1+ 2d which add to 3a1+ 2d, not "3d".
3a1+ 2d= 30
And for the squares, you want a1^2+ (a1+ d)^2+ (a1+ 2d)^2= a1^2+ a1^2+ 4a1d+ d^2+ a1^2+ 4a1d+ 4d^2 which gives
3(a1)^2+ 8a1d+ 4d^2= 692.
d = 10 - a1
No, as above, d= 15- (3/2)a1.
thank you
I don't understand, how come a1 + a2 + a3= a1 + a1 +d + a1 + 2d = 3a1 + 2d and not
3a1 + 3d. What happened to that one d
3a1 + 3d is right.
Can we drop the "a1"? I'm used to calling the first term of an AP simply "a".
I get a = -4, d = 14 to satisfy the condition that this is an increasing progression.
The sum of the first 15 terms is 1410.
I'm not sure why the textbook is saying the first term is 10, because that's wrong. But the sum IS 1410.
How did you calculate S15? What answer did you get?
EDIT: The textbook method MASSIVELY simplifies the algebra, so I like it. But remember that what they're calling a is the *second* term, and that's calculated to be 10. So the first term is still 10 - 14 = -4.
The AP goes: -4, 10, 24,...,192 up to the first 15 terms.
I tried to combine those 2 formulas but it didn't work. I tried using another case where there are 2 red balls and 2 blue balls only so when combining the formula I got ##\frac{(4-1)!}{2!2!}=\frac{3}{2}## which does not make sense. Is there any formula to calculate cyclic permutation of identical objects or I have to do it by listing all the possibilities? Thanks
Essentially I just have this problem that I'm stuck on, on a sheet about complex numbers: Show that, for ##|r|<1,## $$1+r\cos(x)+r^2\cos(2x)+r^3\cos(3x)...=\frac{1-r\cos(x)}{1-2r\cos(x)+r^2}$$ My first thought was to express it as a geometric series, where the real part of the sum of the series would be the series you see above: $$1+re^{ix}+r^2e^{2ix}+r^3e^{3ix}...$$ The sum of this series is just: $$\frac{(re^{ix})^n-1}{re^{ix} - 1}$$ I'm having some trouble trying to figure out what to...
