Continuous functions on metric space, M
If every continuous function on a metric space M is bounded, it implies that the image of any continuous mapping from a set X to M is contained within a bounded subset of M. A function f:X→M is considered bounded if there exists a point x in X and a radius ε such that the entire image f(X) fits within a ball of radius ε centered at f(x). The discussion highlights the need for context to fully understand the implications of boundedness in relation to continuous functions. Additionally, the continuity of the identity function f(p) = p indicates that M itself must also be bounded. Understanding these concepts is crucial for analyzing the properties of continuous functions within metric spaces.
roman93
If every continuous function on M is bounded, what does this mean?
I am not sure what this function actually is... is it a mapping from M -> M or some other mapping? Is the image of the function in M? Any help would be greatly appreciated!
Mathematics news on Phys.org
I suggest that you explain where you saw this statement and quote it exactly.
A map f:X\rightarrow M where X is a set and M is a metric space, is called bounded if the image f(X) is bounded. This means that there is an x\in X and an \varepsilon>0 such that f(X)\subseteq B(f(x),\varepsilon).
This is what I would call bounded. But you will need to specify the context.
Since f(p)= p is continuous, one thing that tells you is that M itself is bounded!
Seemingly by some mathematical coincidence, a hexagon of sides 2,2,7,7, 11, and 11 can be inscribed in a circle of radius 7. The other day I saw a math problem on line, which they said came from a Polish Olympiad, where you compute the length x of the 3rd side which is the same as the radius, so that the sides of length 2,x, and 11 are inscribed on the arc of a semi-circle. The law of cosines applied twice gives the answer for x of exactly 7, but the arithmetic is so complex that the...
Thread 'Video on imaginary numbers and some queries'
Hi, I was watching the following video. I found some points confusing. Could you please help me to understand the gaps? Thanks, in advance! Question 1: Around 4:22, the video says the following. So for those mathematicians, negative numbers didn't exist. You could subtract, that is find the difference between two positive quantities, but you couldn't have a negative answer or negative coefficients. Mathematicians were so averse to negative numbers that there was no single quadratic...
Thread 'Unit Circle Double Angle Derivations'
Here I made a terrible mistake of assuming this to be an equilateral triangle and set 2sinx=1 => x=pi/6. Although this did derive the double angle formulas it also led into a terrible mess trying to find all the combinations of sides. I must have been tired and just assumed 6x=180 and 2sinx=1. By that time, I was so mindset that I nearly scolded a person for even saying 90-x. I wonder if this is a case of biased observation that seeks to dis credit me like Jesus of Nazareth since in reality...
