DG method for nonlinear elliptic PDE
hkcool
Preface: just want to start by saying that I'm 99% sure I'm having a stability issue here in the way I'm implementing the time step since if I set \Delta t \ge 1 then for any stopping time > 1, the algorithm works as it should. For time steps smaller than 1, as the time step gets smaller and smaller the DG solution diverges to the point where the system is singular. This seems REALLY weird to me since I always thought that the method becomes unstable if you take the time step too large.I'm doing a small undergrad research project for a professor and the goal is to implement the DG method for a time-dependent 1D problem:
<br /> \frac{\partial u(x,t)}{\partial t} - \frac{\partial}{\partial x}\left(\alpha(u) \frac{\partial u(x,t)}{\partial x}\right) = f(x,t)<br />
My code works for the non-time dependent case for all cases I could think to test for. Anyway, I'm only supposed to modify the code to add on the time-dependent term:
<br /> \frac{\partial u}{\partial t} \approx \frac{u^{i} - u^{i-1}}{\Delta t}<br />
Multiply by the test function \phi(x) and integrate:
<br /> \frac{1}{\Delta t}\left( \int_{\Omega}{u^{i}\phi(x)} - \int_{\Omega}{u^{i-1}\phi(x)} \right)<br />
Anyway I add these terms to the Jacobian as necessary (u^{i-1} is a known constant so it doesn't contribute?). If we call \int_{\Omega}{u^{i}\phi(x)} the mass matrix M, then essentially what I'm doing is adding \frac{1}{\Delta t}M to the Jacobian and then both terms to the F(u) in the system.
Now, the weird part is that my code works if \Delta t \ge 1 and gives me the correct solution every time, but as soon as \Delta t &lt; 1 then the solution gets a bit odd (BC's are still correct but the 'curvature' is not). And if I make the time step small enough then I just get the error that my Jacobian is singular/close to singular.
I know it's hard to say without looking at the code (and I don't want anyone to do that -- I genuinely want to figure this out on my own) but is the process I described above for time modification correct?
I't not entirely clear to me what you are doing. Are you implementing a space-time discontinuous Galerkin method?
You could first try to just discretize with Galerkin in space, and just do explicit timestepping (don't do the test-function thing). For a relatively simple problem like this, you might be able to get an explicit stability criterion using von Neumann stability analysis, but maybe only for f(x,t) = f(x) and even then, maybe only if it's simple.
I'm a bit suspicious about that the timestep limit is dt==1 for all cases. Is this true even if you change the diffusion constant by a factor of 10?
Are there any good visualization tutorials, written or video, that show graphically how separation of variables works? I particularly have the time-independent Schrodinger Equation in mind. There are hundreds of demonstrations out there which essentially distill to copies of one another. However I am trying to visualize in my mind how this process looks graphically - for example plotting t on one axis and x on the other for f(x,t). I have seen other good visual representations of...
