Can a voltmeter help troubleshoot a ceiling fan remote control battery issue?
A voltmeter can be useful for troubleshooting a ceiling fan remote control battery issue by measuring voltage at various points on the circuit board. Users suggest checking for any components that may be drawing excess current, which could lead to rapid battery depletion. The design of the remote may inherently contribute to the problem, indicating a potential manufacturing flaw. Reaching out to the manufacturer for a replacement is also recommended. Ultimately, diagnosing the issue may require careful voltage measurements to identify any abnormal current draw.
fisico30
Hello forum,
I have a ceiling fan with a remote control. The battery dies too quickly. There is only one IC in the little circuit board. I would like to understand where the issue is.
Can I do that with a voltmeter? But where would I look? What approach? Where would I measure the voltage to troubleshoot it?
Thanks,
fisico30
Unfortunatly I doubt there is much you will be able to do. It is probably just a poorly designed product. I would reach out to the manufacturer and ask for a replacement.
Thank you.
It does not seem a complicated device...maybe something is drawing current and discharging the battery too fast...
hard to tell.
thanks
fisico30
Hi all I have some confusion about piezoelectrical sensors combination. If i have three acoustic piezoelectrical sensors (with same receive sensitivity in dB ref V/1uPa) placed at specific distance, these sensors receive acoustic signal from a sound source placed at far field distance (Plane Wave) and from broadside. I receive output of these sensors through individual preamplifiers, add them through hardware like summer circuit adder or in software after digitization and in this way got an...
I have recently moved into a new (rather ancient) house and had a few trips of my Residual Current breaker. I dug out my old Socket tester which tell me the three pins are correct. But then the Red warning light tells me my socket(s) fail the loop test. I never had this before but my last house had an overhead supply with no Earth from the company. The tester said "get this checked" and the man said the (high but not ridiculous) earth resistance was acceptable. I stuck a new copper earth...
Thread 'Beauty of old electrical and measuring things, etc.'
Even as a kid, I saw beauty in old devices. That made me want to understand how they worked. I had lots of old things that I keep and now reviving. Old things need to work to see the beauty. Here's what I've done so far. Two views of the gadgets shelves and my small work space: Here's a close up look at the meters, gauges and other measuring things: This is what I think of as surface-mount electrical components and wiring. The components are very old and shows how...
