Gold Cap Supercap Leak - Expert Advice Needed
  • Thread starter Thread starter ramonegumpert
    Gold
Gold Cap supercapacitors, specifically 3.3 Farads at 2.5V, can experience self-discharge, which may occur even when not connected to a load. The rate of discharge is crucial for diagnosing the issue, as a rapid discharge could indicate a problem. Experts suggest measuring the discharge rate to determine if it falls within normal parameters for this type of capacitor. If the discharge is unusually fast, it may signal a leak or internal failure. Understanding these factors is essential for effective troubleshooting and ensuring optimal performance.
ramonegumpert
Dear Experts
I am using Gold Cap super capacitors. About 3.3 Farads ones at 2.5V.
When I charged it to 2.5V, it immediate starts to discharge within a few seconds even when not connected to load.
Is this normal?
Thank you for reading.
Best regards
Ramone
How did you determine the discharge is occurring? What is the rate of discharge?
Hi all I have some confusion about piezoelectrical sensors combination. If i have three acoustic piezoelectrical sensors (with same receive sensitivity in dB ref V/1uPa) placed at specific distance, these sensors receive acoustic signal from a sound source placed at far field distance (Plane Wave) and from broadside. I receive output of these sensors through individual preamplifiers, add them through hardware like summer circuit adder or in software after digitization and in this way got an...
I have recently moved into a new (rather ancient) house and had a few trips of my Residual Current breaker. I dug out my old Socket tester which tell me the three pins are correct. But then the Red warning light tells me my socket(s) fail the loop test. I never had this before but my last house had an overhead supply with no Earth from the company. The tester said "get this checked" and the man said the (high but not ridiculous) earth resistance was acceptable. I stuck a new copper earth...
Thread 'Beauty of old electrical and measuring things, etc.'
Even as a kid, I saw beauty in old devices. That made me want to understand how they worked. I had lots of old things that I keep and now reviving. Old things need to work to see the beauty. Here's what I've done so far. Two views of the gadgets shelves and my small work space: Here's a close up look at the meters, gauges and other measuring things: This is what I think of as surface-mount electrical components and wiring. The components are very old and shows how...
