What is the mechanism of cooling?Mechanism of Cooling: Explained
  • Thread starter Thread starter sriram123
    Cooling Mechanism
Cooling occurs as heat energy transfers from a higher temperature body to a lower temperature body through molecular interactions, seeking thermal equilibrium. This process is primarily explained by the average kinetic energy of the molecules, where increased vibrations in the hotter body lead to energy transfer. As molecules collide, energy propagates through conduction, similar to a domino effect, where agitation spreads from the heated source. The analogy of calming friends at a party illustrates how energy disperses until the system stabilizes. Understanding this mechanism is crucial for grasping fundamental thermodynamic principles.
sriram123
Hi all,
I am not clear with the concept of "Cooling" a body.I know that the temperature of a body is the average kinetic energy of the molecules or atoms in the body.When heat energy is supplied,the molecules have more vibrations and hence the temperature increases.Let us have two bodies at temperatures t1 and t2 where t2 is less than t1.If they are physically contacted (Let us assume heat transfer takes place purely by conduction).Then how does this heat transfer takes place in molecular level?.How does energy flow take place from body 1 to body 2?.(I know that heat flows from high temperature to low temperature but how?).
sriram123 said:
Hi all,
I don't know about a quantum mechanical description, but a classical description would say that the average kinetic energy of the modes of oscillation among the constitutive molecules in bodies t1 and t2 would try to seek equilibrium. This would be manifested as the transfer of heat. How does that happen? Probably in a fashion similar to the volume conduction of current in biological tissue, or..How about this? You're at a party and you and all your friends are jacked up on adrenaline becasue you're having so much fun. However, its your house and you know the noise complaints are coming soon. So..you grab one of your friends who's bouncing off the walls and try to calm him down..So far so good until another buddy comes flying across the room and now you have to grab him too and calm him down. Of course it doesn't take doing this to too many other buddies before you begin to get tired and "cool" down. Of course, by this point, everyone has cooled down a bit, and now the party is more manageable:-p
To put it another way, it's a propagation effect, like falling dominoes, a mechanical agitation that spreads radially from the heated source until equilibrium is achieved in the bounded system.
Did that help?
Consider an extremely long and perfectly calibrated scale. A car with a mass of 1000 kg is placed on it, and the scale registers this weight accurately. Now, suppose the car begins to move, reaching very high speeds. Neglecting air resistance and rolling friction, if the car attains, for example, a velocity of 500 km/h, will the scale still indicate a weight corresponding to 1000 kg, or will the measured value decrease as a result of the motion? In a second scenario, imagine a person with a...
Thread 'Gauss' law seems to imply instantaneous electric field propagation'
Imagine a charged sphere at the origin connected through an open switch to a vertical grounded wire. We wish to find an expression for the horizontal component of the electric field at a distance ##\mathbf{r}## from the sphere as it discharges. By using the Lorenz gauge condition: $$\nabla \cdot \mathbf{A} + \frac{1}{c^2}\frac{\partial \phi}{\partial t}=0\tag{1}$$ we find the following retarded solutions to the Maxwell equations If we assume that...
Dear all, in an encounter of an infamous claim by Gerlich and Tscheuschner that the Greenhouse effect is inconsistent with the 2nd law of thermodynamics I came to a simple thought experiment which I wanted to share with you to check my understanding and brush up my knowledge. The thought experiment I tried to calculate through is as follows. I have a sphere (1) with radius ##r##, acting like a black body at a temperature of exactly ##T_1 = 500 K##. With Stefan-Boltzmann you can calculate...
