Questions about Derivatives and Continuity.
Bachelier
1. Is this the only example of a function ##f(x) \in C^1([0,1])## with discontinuous derivative
$$f(x) = \begin{cases}
x^2 sin(\frac{1}{x}) & \textrm{ if }x ≠ 0 \\
0 & \textrm{ if }x = 0 \\
\end{cases}$$
It seems this example is over-used. Do we have other examples besides this one in whatever metric space?2. Also, can a function from a disjoint set be continuous (under the usual metric)?
For instance
##H(x) \ : \ [-∞,-1] \cup [1,∞] → \mathbb{R}##
## \hspace{5 cm} x \mapsto |x| ##​
Take,
f(x)=-x2/2 , x<0
f(0)=0
f(x)=x2/2 , x>0
Then f'(x)=|x| .
Try also using the fact that every a.e. continuous function is Riemann-integrable and
the FThm of Calc.
Bachelier said:
2. Also, can a function from a disjoint set be continuous?
For instance
Yes; consider a basic open set (a,b) in ℝ . What is its inverse image under f? Check that its
open under the ( I assume you're using) subspace topology of the domain.
EDIT: Like Ivy wrote, the statement disjoint set may be imprecise. I think you mean either a disconnected set, or a set that is not a continuum.
What do you mean by as "disjoint" set? In topology one defines a function, from topological space A to topological space B, to be "continuous" if and only if the inverse image of an open set is open. That is, f:A-> B is continuous if and only if, for any open set X in B, f-1(X) is open in A.
One type of "disjoint" set might be one with the "discrete" topology in which every set is "open". If A has the discrete topology, the f:A-> B for any B is trivially continuous. On the other hand, f:B->A generally will NOT be continuous.
\end{cases}$$
I wish to remark that differentiation doesn't necessarily need to make sense in arbitrary metric spaces.
For instance
That is continuous.
everything under the Euclidean metric
A sphere as topological manifold can be defined by gluing together the boundary of two disk. Basically one starts assigning each disk the subspace topology from ##\mathbb R^2## and then taking the quotient topology obtained by gluing their boundaries. Starting from the above definition of 2-sphere as topological manifold, shows that it is homeomorphic to the "embedded" sphere understood as subset of ##\mathbb R^3## in the subspace topology.
