Notation Confusion in Linear Transformations
The notation {f∈F(ℝ,ℝ): f(3)=5} indicates that 'f' is a function mapping real numbers to real numbers, specifically defined such that f(3) equals 5. This does not imply that the function's range encompasses all real numbers; rather, it suggests that the range is a subset of the real numbers. Understanding this distinction is crucial for interpreting linear transformations correctly. The confusion often arises from the assumption that the notation implies a broader range than it actually does. Clarifying these notational meanings is essential for grasping the concepts of linear transformations.
Offlinedoctor
I'm just having trouble understanding some of the notations given, when attempting questions such as the following:
{f\inF(ℝ,ℝ): f(3)=5}.
Is it just saying that, the function 'f' spans all real values?
That is saying that f is a function from the set of real numbers to the set of real numbers, such that when x= 3, f(x)= 5.
It does NOT necessarily mean that the range of f includes all real numbers, just that the range is some subset of the real numbers.
I tried to combine those 2 formulas but it didn't work. I tried using another case where there are 2 red balls and 2 blue balls only so when combining the formula I got ##\frac{(4-1)!}{2!2!}=\frac{3}{2}## which does not make sense. Is there any formula to calculate cyclic permutation of identical objects or I have to do it by listing all the possibilities? Thanks
