Where Do Electrons Come From in DC Generated Current?
  • Context: High School
  • Thread starter Thread starter yoga face
    Current Dc
The discussion revolves around the origins of electrons in direct current (DC) generated from sources like batteries and generators, contrasting this with alternating current (AC). Participants explore the nature of electron movement in circuits, the implications of using DC versus AC, and the mechanics of electron flow in conductive materials.
  • Some participants assert that in a DC circuit, electrons do not need to be newly created; they are pushed from existing free electrons in the metal wire.
  • Others clarify that both AC and DC require a complete circuit for electron flow, with the Earth potentially serving as a return path.
  • A participant compares the flow of electrons in a circuit to water being pumped through pipes, emphasizing that no new electrons are needed, only the movement of existing ones.
  • There is a discussion about the speed of electron movement versus the speed of the electrical signal, with some noting that while electrons drift slowly, the signal travels much faster.
  • One participant questions the need for a starting point for electron flow in DC, suggesting that once electrons leave their starting point, they must be replaced.
  • Another participant challenges the notion of electrons needing to be replaced, arguing that in a solid metal, electrons occupy a shared conduction band that allows for flow in both AC and DC.
  • Some participants mention the limitations of chemical reactions in batteries, which can only generate electrons at a certain rate, affecting the current delivered.
Participants express differing views on the nature of electron flow in DC versus AC, with some asserting that the mechanics are fundamentally similar while others emphasize distinct characteristics. The discussion remains unresolved regarding the implications of these differences and the necessity of electron replacement in DC circuits.
There are unresolved questions about the assumptions regarding electron flow, the role of chemical reactions in batteries, and the implications of using AC versus DC for power transmission.
yoga face
in DC there is a movement of electrons
IE in a battery there is an excess of electrons chemically stored in one end that desire to travel to the other side of the battery where there are a shortage of electrons
where do the electrons come from in a DC generated current ?
if electrons do not travel down the line to the resistance in generated DC is this not AC ?
What do you mean by DC generated current? a battery current?
AC is the movement of electrons through a resistance in an alternating manner, unlike in DC where electrons move in one direction.
I think you need to have an understanding of AC and DC.
A DC generator doesn't need to create a bucket full of "new" electrons. Metal atoms readily give up their outer shell electrons. The generator just needs to push these so called "free" electrons around.
Consider a central heating system. That has a pump which circulates water around the system from the boiler (called a kettle in some countries) to the radiators. The pump doesn't need to create "new" water it just pumps water already in the pipes around.
understood
what i do not understand is the following
there was a great debate among Edison and others as to what electricity Niagara falls should produce (AC or DC)
AC won out because it loses less power in the transmission of it down the wires (energy loss comes mostly through heat loss which is why they cannot bury transmission wires as they would catch on fire)
If they had decided to produce DC where were the electrons going to come from that moved down the current ? Would there have to have been a complete circuit bringing the electrons back to the generating plant at Niagara ?
thx
DC vs AC it makes no difference.
The electrons would come from the metal wire. See my previous reply.
Yes but again that has nothing to do with AC vs DC. A return path is needed for BOTH.
The planet Earth can be used for the return path.
thx
They would come from the same place they do in a AC circuit, the wiring.
http://www.physicsclassroom.com/Class/circuits/u9l2e.cfm
Mr watters i am lost
In a DC battery there are excess electrons at one end and a negative supply at the other
when the circuit is complete the electrons flow from excess supply to negative supply
when they have established equilibrium the battery is "dead"
how would this "flow" of electrons happen if Niagara Falls produced DC?
the way i understand it the electrons in AC come from the metal in the wire (as you pointed out) but they do not flow through the wire they agitate back and forth as the generator changes north pole to south pole agitating the electrons
in DC the electrons flow from one atom to the next (in AC they stay in their original orbit) so there has to be a starting point for the electron
once having left its starting point it needs to be replaced so we need an excess of electrons or a circuit that returns the electrons
where in my thinking am i wrong?
thx
Go back to the central heating model I posted earlier..
DC - the pump runs in one direction all the time.
AC - the pump changes direction at regular intervals.
In neither case does there need to be new water added to the pipework, nor an "excess of water". Nor does there need to be a "starting point".
It's also wrong to think of electrons as flowing all the way around a circuit. Even for DC it's best to imagine it as a queue of electrons. When you push the first one in the queue a wave travels down the line until the one at the end moves. It appears as if one electron has made the trip but that's not the case. Only the wave has made the trip. The waves moves very fast but electrons actually move quite slowly down the wire - it varies but it's on the order of mm per second.
There isn't a huge pile/excess of electrons sitting in the battery ready to go. Think of it as a chemical reaction that's capable of generating electrons one at a time. There is a limit to how fast the chemical reaction can go and that limits how much current the battery can deliver.
thx
i am starting to understand
i just read where actual electron movement down the line is called "drift flow" and is very, very slow
it is the excitment of electrons that travels quickly because of the potential difference between the ends of the circuit
however, there is some movement down the line of electrons in DC where
these electrons move into the orbit of another atom (unlike AC where the stay in the same orbit) but unlike AC there is a "drift flow" down the line so do they not have to be replaced?
ok
there is a potential difference between the ends of the battery ie the ability to excite the electrons into movement with an electronic signal
when the circuit is turned on an electric signal travels at the speed of light charging the electrons(the charge itself does not travel)
Not true. Individual atomic orbitals have little to nothing to do with this. In a solid metal the moving electrons all occupy the conduction band (which is shared by the entire metal) and easily flow everywhere throughout the metal. This happens in both AC and DC circuits. The only difference is that AC circuits alternate the polarity of the voltage and thus the direction of current.
yoga face said:
ok
To understand how batteries work you would need to understand the chemical reaction taking place inside it. I leave that to someone more experienced that myself.
then please explain this
"You never need to replace electrons because they always come back.
This is why you need two prongs on a plug for it to work. Electrons go in one and out the other. Passing through the device is what allows energy to be transferred."
Dr. Ken Mellendorf
Physics Instructor
Illinois Central College here Dr Mellendorf states electrons flowing down the line (from high to low potential difference I presume) is what causes electricity to do its work does he not?
clearly i am not well anointed in physics and greatly admire those who are
i am trying real hard "The electrons do indeed flow. When the circuit is closed, an electric field is set up in the entire wire from the generating plant to the user and back again on another wire -- a closed circuit is required! A wire is a conductor precisely because some of the electrons are free to move when pushed by an electric field.
The closed circuit is required so the electrons can flow in a closed circuit; no electrons are lost! "
Dick Plano, Professor of Physics emeritus, Rutgers University so you do need a complete circuit
grounding will not suffice (is Plano referring to DC or AC or both?) is the circuit needed to capture drift ( electron flow down the line )?
is it the charge of each electron that transfers energy to the resistance?
When an electron transfers energy does it lose its charge? then recapture it from the potential difference? i am getting contradictory answers but i suspect this is because each answer by itself is an incomplete picturecheers
does the Earth act as a wire that is part of the circuit, or as a capacitor inserted into the circuit?
nsaspook said:
I know you are and it really is a shame that you have to.
You might start here for a fresh start with good answers: http://amasci.com/miscon/eleca.html#cflow
http://amasci.com/miscon/elect.html
thx a bunch my preconceptions are wrong (thank the public schools )have i got this right in your link it is stated
"A battery can send electric energy to a light bulb, and the bulb changes electrical energy into light. "
so what is energy?
Energy is Charge * Voltage. correct?
You need both the current flow and the voltage differential for the bulb to light up.
Also
the magnetic fields contain the energy, however they will not light something up until a potential change (voltage) in the field takes place.
In short, energy causes the filament to light up, however one of the components of electrical energy is the existence of charge flow (current).
so what kills you the energy (charge flow ie current * voltage ie potential diffeence) in the electro magnetic field or is it the current (charge flow) alone and separate from the energy ?
in the link he says "When lightning strikes , the spreading electric currents in the ground can kill anyone standing nearby"
he does not say the current times voltage (energy) kills youcheers
In some commercial power systems, the return [negative] path is earth...in others it is ground wires..in either case the electric potential moves electrons along a CLOSED circuit..a continuous path.
ok...
But CHARGE is not current flow...current flow is ' i'...or 'I'...
...POWER is current times voltage: P = IE, and charge, Q, is IT
exactly...
Close, but you again have energy and power mixed up. POWER causes the filament to light.
WATTS, for example, a common measure of bulb strength, is a measure of POWER. Power is energy per unit time.
tremendous NATY
getting the concepts is tricky for a Canadian from the country
one more
in commercial power stations the power is AC
in AC i thought electrons move back and forth while staying within their own orbit (unlike DC where you do have drift) negating the need for a return wire whose job it is to return the electrons that have drifted
if the power station produced DC (which can easily be done) then you would need a return wire(by ground wire do you mean return wire that goes back to the power plant to complete the circuit?)cheers from Canada
Get rid of this idea of electrons in 'orbits'. The electrons within the metal that move are NOT bound to individual atoms. They are bound to the material as a whole. If they were bound to individual atoms, the resistance would be extremely high, as in an insulator.
See the following link: http://en.wikipedia.org/wiki/Conduction_electron
And here: http://en.wikipedia.org/wiki/Electrical_conduction#Band_theory_simplified
cheers from Canada
You need a return path for both AC and DC. You CAN do this with the Earth itself, and it is indeed done in certain situations, but you almost always have a metal wire running from the generators, out to the distribution system, and then back again to complete the circuit.
Draakith posts
yes.
If you look in an electrical outlet in a home in the US, you'll find standard color wiring:
Black is 'hot', say plus 120 volts,..that's the one which may SHOCK you directly.
white is 'neutral'...actually the return wire,
and is also connected to ground in your fuse or circuit breaker main electrical panel.
green is ground for safety...it does NOT normally carry any current.
For a 240 volt circuit, in addition to the above, is a second 'hot' wire which is red.
It may help you to consider that for each half cycle (1/120 th of a second), even AC systems are DC. By that I mean the current flows in only one direction for the half cycle. Even within that frame, no electrons a are crated or destroyed. Electrons flow put of the negative terminal and other electrons are pushed into the positive terminal instan try instant.
Try thinking of only one millisecond. Within that time, there is no difference between AC and DC, yet Ohm's Law still applies. E=I*R Also, within a milliseconds there is no appreciable electron drift. The queue analogy works well. The source pushes some electrons into the negative terminal and at the apsame time the closed circuit pushes other electrons into the positive terminal. Think of the queue as a pipe full of ping pong balls.
only for pure resistors, of course (ie, not capacitors or inductors) :wink:
Naty1 said:
Draakith posts
yes.
what is in the return white wire?
an electomagneic field wth no energy waves?
has not the energy of the electromagnetic waves been used by the resistance?is there any difference between ac and dc electron drift ?
I'm not sure, but I think the labeling of "hot" and "return" is just a matter of convenience so you know which wire is which. Both wires have full current flowing through them.
It has been consumed by the load and the circuit and turned into either work or heat.
is there electron drift in AC ?
Of course, it just alternates back and forth at the frequency of the circuit. In mains power lines in the U.S. that would be 60 hz.
then is the ground wire safe to touch if the energy has been used by the resistance?
NEVER touch part of the circuit unless you are certain the power has been removed. If there is a fault the current is routed to ground through the ground wire.
THX FOR THE WARNING but in theory can the return or grounded wire be touched because the resistance has used up the energy of the electromagnetic waves ?
double cheers from Canada
No, but I'm not sure I have the required knowledge to explain why. The following is my attempt to figure it out for myself and I don't guarantee that it is correct or accurate.I THINK it may be because there is no potential difference between the ground wire and the return wire since the live wire isn't connected to ground. (Otherwise you'd have a parallel circuit) If you were to connect a ground wire to the live wire as well as the return wire, current may begin flowing through both ground wires as a path has been created through the ground itself.
Imagine a battery with a single resistor connected between the two terminals. Take a piece of wire and connect it to the negative side and then connect the other end to ground. Current doesn't flow from the ground to the negative terminal because then you would have more current leaving the positive terminal and moving through the circuit than there is entering the negative terminal through that circuit. In other words, total current leaving the positive terminal would be less than the total current entering the negative terminal, as you would add the total current of the circuit PLUS the current of the ground wire. Obviously this cannot happen, as current leaving the positive terminal and entering the negative terminal must be equal, so there must be zero current flowing through the ground wire. Since there is zero current flowing through the ground wire, the voltage drop across it is zero and you cannot be shocked by it.
Similarly, current flowing through the live and return wires MUST be equal (unless there is a fault), so no current can flow through the ground wire as that would increase the current in the return wire. Again, since no current is flowing there must be zero voltage drop and zero potential difference. Therefore no shock.
Anyways, I hope that makes sense and I hope that's correct, but again I'm not 100% sure.
  • · Replies 22 ·
  • · Replies 36 ·
  • · Replies 17 ·
