Solve Series S_n: 1056, 1088, 1120, 1332
  • Thread starter Thread starter klen
    Series
The series S_n is defined as S_n = ∑_{k=1}^{4n} {(-1)^{k(k+1)/2}} {k^2}. The discussion suggests calculating the sum for specific values of n, particularly focusing on the cases of 4m-3, 4m-2, 4m-1, and 4m. It notes that as n increases by 1, the series adds four new terms, consisting of two positive and two negative contributions. For n=1, the sum equals 20, and for n=2, it equals 72, indicating a pattern related to the number of terms. The values S_n can take include 1056, 1088, 1120, and 1332.
klen
S_n = \sum_{k=1}^ {4n} {(-1)^\frac{k(k+1)}{2}} {k^2}.
Then Sn can take what values among:
Mathematics news on Phys.org
hi klen! :wink:
simplest way is probably to do the sum for 4m-3,4m-2,4m-1,4m (only) first …
what do you get? :smile:
Did you, for example, notice that every time n increases by 1, the sum has 4 new terms, two negative and two positive? Do you notice that for n= 1, so there are 4 terms, the sum is 20= 4(5) and when n= 2, so there are 8 terms, the sum is 72= 8(9)?
Suppose ,instead of the usual x,y coordinate system with an I basis vector along the x -axis and a corresponding j basis vector along the y-axis we instead have a different pair of basis vectors ,call them e and f along their respective axes. I have seen that this is an important subject in maths My question is what physical applications does such a model apply to? I am asking here because I have devoted quite a lot of time in the past to understanding convectors and the dual...
Insights auto threads is broken atm, so I'm manually creating these for new Insight articles. In Dirac’s Principles of Quantum Mechanics published in 1930 he introduced a “convenient notation” he referred to as a “delta function” which he treated as a continuum analog to the discrete Kronecker delta. The Kronecker delta is simply the indexed components of the identity operator in matrix algebra Source: https://www.physicsforums.com/insights/what-exactly-is-diracs-delta-function/ by...
