Water in evaporative cooler reservoir looses heat?
  • Thread starter Thread starter Stephen Tashi
    Cooler Heat Water
A typical evaporative cooler operates by pumping water over fiber pads while a blower draws outside air through them. This process facilitates heat exchange, influencing the temperature of the water in the reservoir. The water that flows over the pads does indeed experience cooling, leading to a net loss of heat as it evaporates. In ideal conditions, both the air and water exiting the system are cooled by the same amount. Thus, the cooler functions similarly to a cooling tower, effectively lowering temperatures through evaporation.
Stephen Tashi
Education Advisor
A typical evaporative cooler works by pumping water from a reservoir in the bottom on the cooler onto fiber pads. A squirrel cage blower sucks outside air over the pads and delivers it into the house. The unevaporated water drips back into the reservoir so whatever heat exchange process goes on at the fiber pads should influence the temperature of the reservoir. Does the return water get a net gain or loss of heat?
In a practical situation, the water in the reservoir is constantly refilled and water also evaporates from its surface. I only wish to consider what heat exchange goes on with the unevaporated water due to its flowing over the pads. The pads of evaporative coolers feel cool relative to the outside air so its tempting to think that the water in the reservoir is being cooled by the trip over the pads.
Science news on Phys.org
You are correct. An evaporative cooler is fundamentally the same as a cooling tower. In a perfect situation, the temperature of the leaving air and water are exactly the same: both are lowered (vs their incoming temperatures) by the process.
