Falling under gravity with decreasing r
The discussion focuses on calculating the time it takes for an object to fall from a height of 1000 km above the moon's surface, assuming no air resistance. The key equation derived is the second derivative of the radius, expressed as a nonlinear differential equation, which relates acceleration to gravitational force. The integration of this equation leads to a formula for time based on energy conservation principles, allowing for the calculation of velocity at various points during the fall. The final expression for time incorporates the radius values and includes a comparison to constant acceleration scenarios to verify accuracy. The complexity of the integral and the potential for errors in calculations are acknowledged, emphasizing the mathematical intricacies involved in gravitational physics.
numberjuggler
If you drop an object from a great height with no air resistance. e.g. 1000 km above the moon. How long will it take to hit the surface?
(GM_{}1M_{}2)/r^{}2 = M_{}2a
r^{}..=k/r^{}2
Hmm this is my first post, not quite getting the symbols.
"The second derivative of r is equal to a constant divided by r squared"
So presumably you integrate that nonlinear differential equation. Somehow.
This is quite an obvious question. It seems like something Isaac Newton would have asked when he first discovered the equations of gravity. A really classic piece of physics. But I can't seem to calculate the answer or find it anywhere.
$$\ddot{r}=\frac{-k}{r^2}$$
As code: $$\ddot{r}=\frac{-k}{r^2}$[/color]$
Or, in ASCII: d^2/dt^2 r = -k/r^2
The minus sign gives the usual convention that r is the (positive) radius and k is positive, too.
With energy conservation, you can calculate the velocity for every point of your motion. The inverse velocity is "time per length" - if you integrate that over the length of the motion, you get the total time.
Here is a rule which can be useful sometimes.
\ddot{r} = \frac{dv}{dt} = \frac{dv}{dr}\frac{dr}{dt} =\frac{dv}{dr} v
Applying this to this situation:
\frac{dv}{dr} v = - \frac{k}{r^2}
v \mathop{dv}= - \frac{k}{r^2}\mathop{dr}
\frac{v^2}{2} = \frac{k}{r} + C_1
We want that at r_0, the velocity is zero
\frac{v^2}{2} = \frac{k}{r} - \frac{k}{r_0}
Next I used the fact that the velocity of the falling object will be negative.
v = \frac{dr}{dt} = - \sqrt{\frac{k}{r} - \frac{k}{r_0}}\;\;\;\; r < r_0
-\int_{r_0}^{r_1} \frac{dr}{\sqrt{\frac{k}{r} - \frac{k}{r_0}}} = \int_0^t dt'\;\;\;\; r_1 < r_0
So the time would be
t = -\frac{1}{\sqrt{k}}\int_{r_0}^{r_1}<br /> \frac{dr}{\sqrt{\frac{1}{r} - \frac{1}{r_0}}} \;\;\;\; r_1 &lt; r_0
Now comes the task of finding this integral.
x = \frac{1}{r} \;\;\;\; dx = -\frac{dr}{r^2}
dr = -r^2 dx = -\frac{dx}{x^2}
-\int \frac{dr}{\sqrt{\frac{1}{r} - \frac{1}{r_0}}} = \int \frac{dx}{x^2\sqrt{x - \frac{1}{r_0}}}
Many steps omitted. Integral obtained using Wolfram Alpha.
\int \frac{dx}{x^2\sqrt{x - \frac{1}{r_0}}}= \frac{r_0<br /> \sqrt{x - \frac{1}{r_0}} }{ x} +r_0^{3/2}tan^{-1}\left(\sqrt{r_0}\sqrt{x - \frac{1}{r_0}}\right)
substituting back for x:
= rr_0\sqrt{\frac{1}{r} - \frac{1}{r_0}} +r_0^{3/2}tan^{-1}\left(\sqrt{r_0}\sqrt{\frac{1}{r} - \frac{1}{r_0}}\right)
note that this will in fact be zero at r = r_0 so we have
t = \frac{1}{\sqrt{k}} \left[ r_0r_1\sqrt{\frac{1}{r_1} - \frac{1}{r_0}} +r_0^{3/2}tan^{-1}\left(\sqrt{r_0}\sqrt{\frac{1}{r_1} - \frac{1}{r_0}}\right) \right] \;\;\;\; r_1 &lt; r_0
I am not sure that I have not made a mistake. One thing you could do to check this is to compare it to the falling time for constant acceleration and see if it is close for small distances.
t = \sqrt{\frac{2(r_0 - r_1)}{g}} = \sqrt{\frac{2r_0^2(r_0 - r_1)}{k}} \;\;\;\; r_1 &lt; r_0
Sorry, I was missing a \sqrt{2}.
t = \frac{1}{\sqrt{2k}} \left[ r_0r_1\sqrt{\frac{1}{r_1} - \frac{1}{r_0}} +r_0^{3/2}tan^{-1}\left(\sqrt{r_0}\sqrt{\frac{1}{r_1} - \frac{1}{r_0}}\right) \right] \;\;\;\; r_1 &lt; r_0
I have recently been really interested in the derivation of Hamiltons Principle. On my research I found that with the term ##m \cdot \frac{d}{dt} (\frac{dr}{dt} \cdot \delta r) = 0## (1) one may derivate ##\delta \int (T - V) dt = 0## (2). The derivation itself I understood quiet good, but what I don't understand is where the equation (1) came from, because in my research it was just given and not derived from anywhere. Does anybody know where (1) comes from or why from it the...
