Why Is There Cold Wind? Investigating the Creation of Wind and Its Temperature"
  • Thread starter Thread starter tony1grendel
    Cold Wind
Wind can feel cold despite its speed due to the principles of kinetic theory, which indicate that temperature is not solely determined by the velocity of air particles. The sun heats the Earth unevenly, causing hot air to rise and create areas of low pressure, which are filled by surrounding air, resulting in wind. This incoming air can be cooler, leading to the sensation of cold wind as it displaces warmer air near the skin. Additionally, the velocity of wind does not directly correlate with temperature, as temperature is determined in a specific frame of reference. Factors like evaporation and humidity further influence how wind is perceived, making it feel colder or hotter depending on the conditions.
tony1grendel
So awhile ago I was thinking about wind.
Sometimes wind is hot but when I think of wind I usually think of cold wind.
Wind seems to be fast moving particles and I know based on the kinetics theory of gases
KE = \frac{1}{2}mv^2 = \frac{3}{2}kT
Maybe, I'm making a wrong assumption but to me this seems that if a particle of gas has a high KE and high v that it will have a high T
So why would there be cold wind. Shouldn't all high velocity wind be hot?
Through my investigation of this I have gotten some info on how wind is created.
From what I can gather
The atmosphere of the Earth that is getting heated
and the hot air rises because it becomes less dense
(here is where I get a little confused and maybe making wrong assumptions)
this causes less pressure in that area of the atmosphere
causing nearby particles of air to fill the uneven pressure (partial vacuum the rising hot air created?)
and so you have wind!
To me it seems if the gases filling the uneven pressure have a low T that it would seem plausible that we would have cold wind BUT wouldn't that air over time heat up because of it's increase in KE?
I know this looks like a wall of text now but this is my thought process
Welcome to PF!
1. Bulk motion is not included in the temperature.
2. Can you calculate at what speed, the KE would make a noticeable difference if converted to heat?
Also, the pressure of the atmosphere is not evenly distributed at anyone time. If a region of low pressure develops, a portion of the atmosphere from a region of higher relative pressure will move in. This movement will also create wind.
Clothes and hair trap a layer of warm air next to your skin. Wind can remove this layer of warm air making it feel colder than it would otherwise.
More..
http://en.wikipedia.org/wiki/Wind_chill
You're right. You are making a wrong assumption. Velocity and energy are frame-dependent quantities -- change the frame of reference and you get different velocities, different kinetic energy. So in which frame are those velocities expressed? The answer is that it is a rest frame of the gas, a frame in which the total momentum is zero.
In other words, wind velocity doesn't come into play in determining temperature in the kinetic theory of gases.
There's also the effect of evaporation if a person is sweating, and the effect of relative humidity.
If the air temperature is around 100°F ~= 38°C or higher, the wind will make it fill hotter still.
http://www.zunis.org/at_least_theres_a_breeze.htm
Thread 'Gauss' law seems to imply instantaneous electric field'
Imagine a charged sphere at the origin connected through an open switch to a vertical grounded wire. We wish to find an expression for the horizontal component of the electric field at a distance ##\mathbf{r}## from the sphere as it discharges. By using the Lorenz gauge condition: $$\nabla \cdot \mathbf{A} + \frac{1}{c^2}\frac{\partial \phi}{\partial t}=0\tag{1}$$ we find the following retarded solutions to the Maxwell equations If we assume that...
Maxwell’s equations imply the following wave equation for the electric field $$\nabla^2\mathbf{E}-\frac{1}{c^2}\frac{\partial^2\mathbf{E}}{\partial t^2} = \frac{1}{\varepsilon_0}\nabla\rho+\mu_0\frac{\partial\mathbf J}{\partial t}.\tag{1}$$ I wonder if eqn.##(1)## can be split into the following transverse part $$\nabla^2\mathbf{E}_T-\frac{1}{c^2}\frac{\partial^2\mathbf{E}_T}{\partial t^2} = \mu_0\frac{\partial\mathbf{J}_T}{\partial t}\tag{2}$$ and longitudinal part...
