How does ultrasound imaging work?
Ultrasound imaging works by generating sound waves from piezoelectric crystals that transmit and receive echoes from body structures. When sound waves reflect back to the transducer, the time taken for the echoes to return is measured, allowing the system to determine the depth and density of the reflecting tissues. The resulting data is processed electronically to create an image displayed on a monitor, with image quality influenced by the frequency and amplitude of the sound waves. Transducers can vary in design, utilizing either single or multiple piezoelectric elements based on system requirements. Understanding these principles often involves studying "inverse problems" in physics, and additional resources are available for deeper learning.
anorred
From what I understand, ultrasound beams are generated from hundreds of piezo crystals that constructively interfere with one another. When the beam is reflected, it returns to the crystals and the crystal directly above the reflection (the crystal that obtains mechanical vibrations) records the data and assumes the reflection point is right underneath the crystal. Data is then interpreted based on the time it takes for the wave to travel back and forth to the crystal. Please help me understand this phenomenon better. I want to know how these images are created.
The time is interpreted as a density - and you also know what sorts of material densities are likely.
The rest is up to the electronic processing - usually done by a computer.
The topic is usually part of a course in "inverse problems" and the exact process is not trivial.
To form an image of internal structures, a transducer is placed against the skin. Transducers can consist of only one piezoelectric element or several, but never "hundreds", depending on the requirements of the system. The transducer sends out high frequency sound waves that reflect off of body structures. The returning sound waves, or echoes, are displayed as an image on a monitor. The image is based on the frequency and strength (amplitude) of the sound signal and the time it takes to return from the patient to the transducer.
There are several technical websites available for learning the principles of operation using the search terms “ultrasonic imaging physics”.
Here are two general descriptions:
https://en.wikipedia.org/wiki/Medical_ultrasonography
http://www.criticalecho.com/content/tutorial-1-basic-physics-ultrasound-and-doppler-phenomenon
Hi there, im studying nanoscience at the university in Basel. Today I looked at the topic of intertial and non-inertial reference frames and the existence of fictitious forces. I understand that you call forces real in physics if they appear in interplay. Meaning that a force is real when there is the "actio" partner to the "reactio" partner. If this condition is not satisfied the force is not real. I also understand that if you specifically look at non-inertial reference frames you can...
I have recently been really interested in the derivation of Hamiltons Principle. On my research I found that with the term ##m \cdot \frac{d}{dt} (\frac{dr}{dt} \cdot \delta r) = 0## (1) one may derivate ##\delta \int (T - V) dt = 0## (2). The derivation itself I understood quiet good, but what I don't understand is where the equation (1) came from, because in my research it was just given and not derived from anywhere. Does anybody know where (1) comes from or why from it the...
