Can Bicycles Generate Enough Power to Run Microwaves?
  • Thread starter Thread starter Optimus Bam
    Microwaves
Bicycles can generate power through an alternator or generator, but using that power for high-demand devices like microwaves would significantly increase pedaling difficulty. The energy required to run such devices would exceed what a human can provide, likely causing the bike to stop. In contrast, powering smaller devices, like an iPod, is feasible and has existing accessories for this purpose. The experience of using a bike generator for a headlamp illustrates that additional power demands make pedaling harder, especially at lower speeds. Overall, while bicycles can generate electricity, their capacity is limited for high-power applications.
Optimus Bam
My friends and I have thought about this for a few years now and still can't come to a conclusion.
If an electronic device was placed on a push bike and could be powered by it (for arguments sake we came up with a microwave) and was turned on while in motion, would the bike become harder to pedal as some, if not most, of the energy would be used to power the bike?
Science news on Phys.org
I'm assuming you're going to generate the electricity by turning the shaft of an alternator or generator. If so, the answer is yes.
How much harder to push? That depends on how much power is needed to run the electrical equipment; but one way or another that power is coming from you pushing the bike.
Yes of course. I have in fact experienced this. I had a pedal bike with a headlamp that was powered by a little generator attached to the wheels. Whenever I turned on the headlamp, the wheels a little harder to push. Of course it should because you can't create energy out of nothing. I discovered that if I was going very slow, I had to push much harder when I turned on the lights, but if a was going faster, I did not have to pedal as hard when turning on the lights. Powering something as big as a microwave oven is going to take more power than human legs can provide. Your bike would grind to a halt once you flipped on the microwave. But charging up an iPod is much more doable. They in fact sell accessories for this very thing:
http://www.gizmag.com/pedalpower-bicycle-charger/12451/
I would like to use a pentaprism with some amount of magnification. The pentaprism will be used to reflect a real image at 90 degrees angle but I also want the reflected image to appear larger. The distance between the prism and the real image is about 70cm. The pentaprism has two reflecting sides (surfaces) with mirrored coating and two refracting sides. I understand that one of the four sides needs to be curved (spherical curvature) to achieve the magnification effect. But which of the...
