Can Automatic Link Title Resolution Be Improved on arXiv.org?
  • Thread starter Thread starter StevieTNZ
Direct links to PDF files on arXiv.org are labeled '403 Forbidden,' although they still lead to the intended documents when clicked. This issue arises from a failure in automatic URL encoding into UBBC, affecting how links are displayed in forum posts. Users noted that quoting the link reveals the underlying problem with the formatting. The discussion highlights the need for improvements in the automatic link title resolution feature to prevent confusion. Addressing this hiccup could enhance user experience on the platform.
StevieTNZ
Hi there,
A direct link to a PDF file on arXiv.org results in the link being named '403 Forbidden'. Not sure what's going on; however clicking on the link takes you to the intended PDF.
So the link doesn't work, but it works?
Can't say I understand what's the problem.
StevieTNZ said:
Hi there,
If you're referring to something like this post: Physicist disentangles 'Schrodinger's cat' debate - Single Post
the weirdness is actually in the post itself - try quoting it and look at the raw bbcode to see what's wrong and how to fix it.
OK, it is automatic URL encoding into UBBC that fails. Try to post just a link to pdf: [noparse]http://arxiv.org/ftp/arxiv/papers/1301/1301.1673.pdf[/noparse] and it will be converted to
Code:
The current format is:
Code:
[noparse]As per the title, the article is [url="http://phys.org/news/2013-08-physicist-disentangles-schrodinger-cat-debate.html"]Physicist disentangles 'Schrodinger's cat' debate[/url]
The paper is http://arxiv.org/ftp/arxiv/papers/1301/1301.1673.pdf[/quote][/noparse]
Back to normal. I was testing a automatic link title resolution feature. Obviously there is a hiccup.
  • Sticky
  • Sticky
48K
