Forced Vibration: Amplitude Of Vibration Changes Periodically?
  • Thread starter Thread starter roshan2004
    Vibration
In forced vibration, the amplitude of vibration does not change periodically; rather, it is the displacement that is periodic. The amplitude represents the maximum displacement and is not a periodic function. When a steady vibration frequency is applied, the amplitude grows exponentially until it reaches a maximum, and upon removal of excitation, it decays exponentially. The frequency remains constant during forced vibration, with only minor 'ringing' effects during transitions. Understanding these distinctions is crucial for accurate analysis of forced vibrations.
roshan2004
In forced vibration, amplitude of vibration changes periodically. Is it right ? I think it is a correct statement, since the amplitude of vibration is a periodic function.
Are you suggesting that you get a 'beat'?
You don't get a beat, just a reduced amplitude of response. The level will depend on the Q of the resonator and the frequency offset.
I think there may be a bit of a terminology confusion here. The displacement is a periodic function in vibration. The amplitude is the maximum displacement, so it is not periodic.
So, does it decays exponentially then... ( I mean amplitude of the forced vibration)
The term 'forced vibration' means that a steady vibration frequency is applied. The result is a 1/exponential growth in amplitude takes place over time, until a max amplitude is reached. When the exitation is removed, there is an exponential decay in amplitude. There is no change in frequency at any time except for a small possible 'ringing' due to a discontinuity on switch on and switch off. But that is not usually considered.
Thread 'Is there a white hole inside every black hole?'
This is what I am thinking. How much feasible is it? There is a white hole inside every black hole The white hole spits mass/energy out continuously The mass/energy that is spit out of a white hole drops back into it eventually. This is because of extreme space time curvature around the white hole Ironically this extreme space time curvature of the space around a white hole is caused by the huge mass/energy packed in the white hole Because of continuously spitting mass/energy which keeps...
Why do two separately floating objects in a liquid "attract" each other ?? What if gravity is an emergent property like surface tension ? What if they both are essentially trying to *minimize disorder at the interfaces — where non-aligned polarized particles are forced to mix with each other* What if gravity is an emergent property that is trying to optimize the entropy emerging out of spin aligned quantum bits
