Question on power plant generators
Power plant generators increase output by requiring more torque from the prime mover, which enhances the torque angle between the stator and rotor voltages, allowing them to be more in phase and additive. This results in a higher current produced in the stator, thus increasing power output. The phase of the current is influenced by excitation and the load's acceptance, while the voltage regulator plays a crucial role in controlling excitation. Additionally, power plants operate generators in parallel, enabling the exchange of reactive (imaginary) current. Understanding these dynamics is essential for grasping the electrical aspects of power generation.
Idea04
I'm trying to understand exactly how power plant generators increase power output. So I will explain what I think is right.
To increase the power output of a generator more torque from the prime mover is required to increase the torque angle between the voltage impressed on the stator from the grid with the voltage impressed on the stator from the rotor field. As the torque angle increases up to 90 degrees the two voltages will be more in phase and be additive which will result in a larger amount of current produced in the stator. Thus increasing the power output.
Can someone correct me, and what happens with the phases between the voltage and current when the torque angle is increased. Is there still a lagging power factor or does the current align with the sum of the two voltages.
I'm probably wrong in my thinking but some clarification would be very much appreciated.
You might want to spend time studying steam turbines. In power plants, power output can be increased or decreased by adjusting the pressure-drop across the turbine, including auxiliary systems like steam-hoggers and condensers that allow the steam to exit the turbine at lower than atmospheric pressure. Good luck with your studies.
Sorry but I'm more interested in the electrical side of it and less on the actual mechanical side of the operation. I have been trying to find info in the internet but so far not successful.
You have it pretty nearly right.
The phase of the current is largely affected by the excitation, and what the load will accept.
Power plant generators are all in parallel so can exchange lots of imaginary(out of phase) current.
You haven't said whether you're assuming constant field or constant terminal volts...
The sad truth is the voltage regulator gets into the act and controls excitation.
Here's an animation I found with a quick Google search:
http://www.ece.umn.edu/users/riaz/animations/syncmotpd.html
It's for a motor, but only difference is sign of torque and in-phase current.
We had some interesting threads a couple years ago with a really cool student named Bassalisk.
https://www.physicsforums.com/showthread.php?t=538388
https://www.physicsforums.com/showthread.php?t=571174
https://www.physicsforums.com/showthread.php?t=614617
http://www.basler.com/downloads/Design_exc.pdf
May you find them interesting, or a cure for insomnia.Do you have a machinery lab in your school? It is a lot of fun to watch the angle of a shaft with a strobe light synchronized to terminal voltage. And it gives you that "feel" for what is going on.
http://www.ece.umn.edu/users/riaz/animations/smswing.html
old jim
Hi all I have some confusion about piezoelectrical sensors combination. If i have three acoustic piezoelectrical sensors (with same receive sensitivity in dB ref V/1uPa) placed at specific distance, these sensors receive acoustic signal from a sound source placed at far field distance (Plane Wave) and from broadside. I receive output of these sensors through individual preamplifiers, add them through hardware like summer circuit adder or in software after digitization and in this way got an...
While I was rolling out a shielded cable, a though came to my mind - what happens to the current flow in the cable if there came a short between the wire and the shield in both ends of the cable? For simplicity, lets assume a 1-wire copper wire wrapped in an aluminum shield. The wire and the shield has the same cross section area. There are insulating material between them, and in both ends there is a short between them. My first thought, the total resistance of the cable would be reduced...
I am not an electrical engineering student, but a lowly apprentice electrician. I learn both on the job and also take classes for my apprenticeship. I recently wired my first transformer and I understand that the neutral and ground are bonded together in the transformer or in the service. What I don't understand is, if the neutral is a current carrying conductor, which is then bonded to the ground conductor, why does current only flow back to its source and not on the ground path...
