Chance of B and C After Accident: 2/5, 3/5
  • Thread starter Thread starter utkarshakash
The initial probabilities of runners A, B, and C were proportional to 5, 3, and 2, respectively, giving them winning probabilities of 5/10, 3/10, and 2/10. After A's accident, which reduces his chance to one-third, the total probability for B and C must equal 2/3. The ratio of B's to C's chances remains unchanged at 3:2. By setting C's chance as "x," B's chance is calculated as (3/2)x, leading to the equations that determine C's chance as 4/15 and B's chance as 2/5. The final probabilities for B and C are thus established at 2/5 and 4/15, respectively.
utkarshakash
Before a race the chances of three runners, A,B,C were estimated to be proportional to 5,3,2; but during the race A meets with an accident which reduces his chance to one-third. What are now the respective chances of B and C?
The ratio of chance of A to B is 5/3. But the chance of A after accident is 1/3. Let chance of B be x. Since the ratio is same ∴ x= 1/5. But the correct answer is just the double of this.
5+3+ 2= 10 so their probabiliities of winning are 5/10, 3/10, and 2/10, respectively.
Your error is assuming A's and B's chances of winning still have the same ratio. That can't be true since A's accident changes A's chance of winning while B's has not changed. It is the ratio of B and C that does not change.
If A's chance after the accident is 1/3, the sum of the other two probabilites must be 2/3. Assuming the relative chances of B and C have not changed, since, originally, B's chance of winning was 3/2 C's, letting "x" be C's chance of winning, B's chance is (3/2)x so that (3/2)x+ x= (5/2)x= 2/3. Dividing both sides by 5/2, x= (2/3)(2/5)= 4/15. C's chance of winning now is 4/15 and B's is (3/2)(4/15)= 2/5.
Likes 1 person
I tried to combine those 2 formulas but it didn't work. I tried using another case where there are 2 red balls and 2 blue balls only so when combining the formula I got ##\frac{(4-1)!}{2!2!}=\frac{3}{2}## which does not make sense. Is there any formula to calculate cyclic permutation of identical objects or I have to do it by listing all the possibilities? Thanks
