Raman Amplification: Understanding its Role in Optical Fibers
Raman scattering, both spontaneous and stimulated, plays a crucial role in optical fibers by enabling signal amplification to compensate for signal loss. Stimulated Raman scattering (SRS) occurs when a second photon interacts with the first, resulting in two coherent, Raman-shifted photons, which can amplify signals at specific frequencies. This amplification process is similar to that of erbium-doped fiber amplifiers (EDFA) but relies on short-lived virtual states. The distinction between acoustic and optic phonons, while primarily frequency-based, can influence the efficiency and characteristics of the amplification process. Understanding these nuances is essential for optimizing optical fiber performance and signal integrity.
eahaidar
Hello
I understood what is the meaning of Raman scattering whether spontaneous or stimulated but I did not understand its importance in the optical fiber
The amplification role is to compensate the loss on the fiber of the signal but how did we do it in the fiber !?
Thank you
Raman scattering is a scattering process with an accompanying vibrational transition, which yields a frequency shift between the incident and scattered photons (called the Raman shift).
Stimulated Raman scattering (SRS) is where Raman scattering occurs in the presence of a second incident photon. This results in two Raman-shifted photons (where ordinarily, the probability of obtaining two Raman-shifted photons from two independent photons is extremely low). Moreover, these photons are coherent. This process is analogous to stimulated emission, hence the name.
SRS can be used to amplify signals at the Raman-shifted frequency by "pumping" it with an intense field at the original, incident frequency - the same way we can amplify a signal using an EDFA.
The difference between Raman amplification and "ordinary" amplification is that the upper Raman state is a short-lived virtual state.
Claude.
Claude.
Ok I started to understand let me ask you this
Why should I care if the phonon is acoustic or optic it is only different in the frequency??
Thread 'Is there a white hole inside every black hole?'
This is what I am thinking. How much feasible is it? There is a white hole inside every black hole The white hole spits mass/energy out continuously The mass/energy that is spit out of a white hole drops back into it eventually. This is because of extreme space time curvature around the white hole Ironically this extreme space time curvature of the space around a white hole is caused by the huge mass/energy packed in the white hole Because of continuously spitting mass/energy which keeps...
