MIMO vs. Vector OFDM: What's the Difference?
  • Thread starter Thread starter janu203
    Difference Vector
Vector OFDM and MIMO are distinct concepts in wireless communication, with vector OFDM being a specific implementation of orthogonal frequency division multiplexing that utilizes vector signals for improved performance. In contrast, MIMO (Multiple Input Multiple Output) employs multiple antennas to enhance data throughput and reliability through spatial diversity. The discussion highlights confusion around the term "vector" in the context of OFDM and MIMO, emphasizing that it can have different meanings in each framework. The relationship between vector blocks and MIMO systems is also questioned, indicating a need for further clarification on these technical terms. Understanding these differences is crucial for grasping advanced communication techniques.
janu203
Is vector OFDM (Orthogonal Frequency division multiplexing) same as MIMO?
What are vector blocks in a MIMO system then?
I know what is Frequency division multiplexing but can't understand orthogonal FDM.
HELP!
OFDM is a form of FDM. In ordinary FDM, carrier spacing is wide enough, including guard bands, to prevent interference between carriers. In OFDM, carrier spacing is very close, so close that carriers actually overlap. This is achieved by having all carriers digitally modulated, and at exactly the same baud rate. Carrier spacing is then chosen such that the center frequency of each carrier cooresponds to a spectral null of all other carriers. (Digital modulation produces sinc spectral envelope).
MIMO is a scheme for using multiple antennas for spatial diversity.
Likes 2 people
ok but do you have any idea of VECTOR OF OFDM? and what are vector blocks of a channel
HELP!
Can you give us some links to the materials you have been reading about this? The term "vector" would have pretty different meanings in the contexts of MIMO and OFDM...
On Performance of Vector OFDM with Zero-Forcing Receiver
I am doing research on this paper. but can't figure out the what's the difference between VOFDM and OFDM? and similarly what are vector blocks
Hi all I have some confusion about piezoelectrical sensors combination. If i have three acoustic piezoelectrical sensors (with same receive sensitivity in dB ref V/1uPa) placed at specific distance, these sensors receive acoustic signal from a sound source placed at far field distance (Plane Wave) and from broadside. I receive output of these sensors through individual preamplifiers, add them through hardware like summer circuit adder or in software after digitization and in this way got an...
I have recently moved into a new (rather ancient) house and had a few trips of my Residual Current breaker. I dug out my old Socket tester which tell me the three pins are correct. But then the Red warning light tells me my socket(s) fail the loop test. I never had this before but my last house had an overhead supply with no Earth from the company. The tester said "get this checked" and the man said the (high but not ridiculous) earth resistance was acceptable. I stuck a new copper earth...
Thread 'Beauty of old electrical and measuring things, etc.'
Even as a kid, I saw beauty in old devices. That made me want to understand how they worked. I had lots of old things that I keep and now reviving. Old things need to work to see the beauty. Here's what I've done so far. Two views of the gadgets shelves and my small work space: Here's a close up look at the meters, gauges and other measuring things: This is what I think of as surface-mount electrical components and wiring. The components are very old and shows how...
