Determining possible trajectories (Classical Mechanics)
MrCreamer
Determine possible trajectories for particle with constant magnitude of velocity |\dot{\vec{r}}| = v0 and constant angular momentum \vec{L} = \vec{L}0
|\dot{\vec{r}}| = v0
\vec{L} = \vec{L}0
I know that L dot is zero and thereby the torque is zero. My intuition tells me that the possibly trajectories would be circles but mathematically, I am not sure where to start.
Look at he definition of L. Perhaps the time derivative of that tells you something
Well, as I said, if \dot{\vec{L}} = 0, then the net torque and net force are zero. The constant velocity magnitude implies that the direction of the velocity vector can change but the speed would remain constant.
If F is zero, then you have
m\ddot{x} = 0
Which implies that x(t) is of some linear form:
x(t) = at + b, where a = v_{0} and b = x_{0}.
I'm assuming the question requires the graphing of the trajectories in phase space and hence would require some form of mathematical development in terms of the energy of the system.
I think BvU meant for you to differentiate ##\vec{L} = \vec{r}\times\vec{F}## and to interpret the result.
By the way, your inference that ##\dot{\vec{L}} = 0## implies ##\vec{F}=0## is not correct.
I meant: differentiate ##\vec L = \vec r \times \vec p## wrt time, knowing ##\vec p = m\dot{\vec r}##. Don't venture into x and y because you have everything you need in polar coordinates.
##|\Psi|^2=\frac{1}{\sqrt{\pi b^2}}\exp(\frac{-(x-x_0)^2}{b^2}).## ##\braket{x}=\frac{1}{\sqrt{\pi b^2}}\int_{-\infty}^{\infty}dx\,x\exp(-\frac{(x-x_0)^2}{b^2}).## ##y=x-x_0 \quad x=y+x_0 \quad dy=dx.## The boundaries remain infinite, I believe. ##\frac{1}{\sqrt{\pi b^2}}\int_{-\infty}^{\infty}dy(y+x_0)\exp(\frac{-y^2}{b^2}).## ##\frac{2}{\sqrt{\pi b^2}}\int_0^{\infty}dy\,y\exp(\frac{-y^2}{b^2})+\frac{2x_0}{\sqrt{\pi b^2}}\int_0^{\infty}dy\,\exp(-\frac{y^2}{b^2}).## I then resolved the two...
Hello everyone, I’m considering a point charge q that oscillates harmonically about the origin along the z-axis, e.g. $$z_{q}(t)= A\sin(wt)$$ In a strongly simplified / quasi-instantaneous approximation I ignore retardation and take the electric field at the position ##r=(x,y,z)## simply to be the “Coulomb field at the charge’s instantaneous position”: $$E(r,t)=\frac{q}{4\pi\varepsilon_{0}}\frac{r-r_{q}(t)}{||r-r_{q}(t)||^{3}}$$ with $$r_{q}(t)=(0,0,z_{q}(t))$$ (I’m aware this isn’t...
Hi, I had an exam and I completely messed up a problem. Especially one part which was necessary for the rest of the problem. Basically, I have a wormhole metric: $$(ds)^2 = -(dt)^2 + (dr)^2 + (r^2 + b^2)( (d\theta)^2 + sin^2 \theta (d\phi)^2 )$$ Where ##b=1## with an orbit only in the equatorial plane. We also know from the question that the orbit must satisfy this relationship: $$\varepsilon = \frac{1}{2} (\frac{dr}{d\tau})^2 + V_{eff}(r)$$ Ultimately, I was tasked to find the initial...
