Restore indirect relations within a transitive relation
The discussion revolves around generating a complete set of pairs from a transitive relation, specifically aiming to include all direct and indirect relationships. An example relation R is provided, and the user seeks a mathematical operator or formula to derive all implicit relations. The current approach involves using composite and union operators iteratively to expand the relation until no new pairs are generated. The user has successfully implemented an algorithm for this process but desires a formal mathematical representation for reporting purposes. The key question is how to express this iterative process mathematically to ensure it reflects the generation of all indirect relations.
mm84010
Hi,
I have a transitive relation and wana build a complete set of pairs that reflect all (direct/indirect) relations among the pairs.
Ex.: suppose I have this relation R = { (1,2), (2,3), (3,5), (5,7), (3,4) }
I wana to produce this relation R oper R = { (1,2), (1,3), (1,4), (1,5), (1,7), (2,3), (2,4), (2,5), (2,7), (3,4), (3,5), (3,7), (5,7) }
I tried to use the composite operator (°), but I got this R U (R ° R) = { (1,2), (2,3), (3,5), (5,7), (3,4), (1,3), (2,4), (2,5), (3,7) } which is not complete. In this case I need a loop operator until all pairs are restored.
Is there an operator that I can used to reflect that?
Thanks in advance.
That isn't a transitive relation. How does this example illustrate your question?
Sorry, Math is not my suppject, but this is how I understand transitive relation:
if A > B and B > C then A > C.
In my example I have , e.g.,
- (1,2) = 1 > 2
- (2,3) = 2 > 3
which conclude that 1 > 3 ==or==> (1,3)
from this new pair I can create another two pairs
- (1,3)
- (3,5) & (3,4) from the relation
I can produce two new pairs (1,5) & (1,4)
an so on
In my research, I have two relations , based on partial order, build independently and I have to compare them.
suppose I have these two
R1 = { (1,2), (2,4) }
R2 = { (1,2), (2,4), (1,4) }
For me, they are equivalent. but How I can use math to prove my case. I am trying to generate/expand the total/all relations among the existing pairs.
Hi,
I am seeking help to derive my formula in set theory.
I will explain my request through the following example:
suppose I have this transitive relation R = { (1,2), (2,3), (3,5), (5,7), (3,4) }
I mean by transitive that since
(1,2) ==> 1 > 2, and
(2,3) ==> 2 > 3
then I can conclude that
1 > 3 or (1,3)
Hence, I can add this pair explicitly to R.
I wana to add all these implicit relations to reach the final relation:
R` = { (1,2), (1,3), (1,4), (1,5), (1,7), (2,3), (2,4), (2,5), (2,7), (3,4), (3,5), (3,7), (5,7) }
Currently, here are the steps I used to build my case
s1 = R ° R = { (1,3), (2,4), (2,5), (3,7) } // compsite operator
s2 = R U s1 = { (1,2), (2,3), (3,5), (5,7), (3,4), (1,3), (2,4), (2,5), (3,7) } // union operator
s1 = s2 ° R = { (1,3), (2,4), (2,5), (3,7), (1,5), (1,4), (2,7) }
s2 = s2 U s1 = { (1,2), (2,3), (3,5), (5,7), (3,4), (1,3), (2,4), (2,5), (3,7), (1,5), (1,4), (2,7) }
s1 = s2 ° R = { (1,3), (2,4), (2,5), (3,7), (1,5), (1,4), (2,7), (1,7) }
s2 = s2 U s1 = { (1,2), (2,3), (3,5), (5,7), (3,4), (1,3), (2,4), (2,5), (3,7), (1,5), (1,4), (2,7), (1,7) }
I stop when s1 produce the same previous relation, and my result is in s2.
I built a computer algorithm for that, but I want a math formula to report my work in formal way.
I don't know if there is an operator reflect the generation of all implicit indirect relations among the elements of set (I read three discrete math books and browsed several math pages), or there is a loop operator that reflect a recursiveness based on a condition (not number of occurrences).
Thanks for any hint,
Reference to papers/books/tutorials are appreciated
I think the correct statement statement of your question is:
If I am given a relation S as a finite set, what algorithm can be used to generate the smallest set R that is a transitive relation and that contains S as a subset?
You have proposed an algorithm. Are you asking for a proof that your algorithm terminates in a finite number of steps and that it produces the desired R?
Likes 1 person
Thanks Stephen,
I had implemented the algorithm and it works fine.
I am trying to put a nice formula in my report to reflect this algorithm.
I was reading documentation about the soundness and completeness of logic formal systems. Consider the following $$\vdash_S \phi$$ where ##S## is the proof-system making part the formal system and ##\phi## is a wff (well formed formula) of the formal language. Note the blank on left of the turnstile symbol ##\vdash_S##, as far as I can tell it actually represents the empty set. So what does it mean ? I guess it actually means ##\phi## is a theorem of the formal system, i.e. there is a...
