Can we escape a black hole's event horizon using another?
adrian_m
I have always assumed once we pass through a black hole's event horizon, we can throw away the return ticket. But I have been thinking - is it really so final?
Consider two identical black holes close to each other with their even horizons overlapping, or nearly so. Is the spacetime on a plane equidistant from the CG of both and orthogonal to the line joining them flat, with each negating the other's gravity?
Is there a possibility that someone on this plane could move along that plane and possibly escape from within the event horizon of both (if they overlap)?
Even if they don't overlap, could one of them negate the effect of the other's gravity sufficiently to allow escape from just inside the event horizon of either?
When two event horizons overlap, you have one bigger event horizon and no possibility of escape. You will quickly end up with one bigger, spherical, BH (after a violent merger with a lot of energy released as gravitational waves). Classically, the only loophole for escape from inside a horizon is via wormhole or matter that violates energy conditions (e.g. tachyons).
OK, so this has bugged me for a while about the equivalence principle and the black hole information paradox. If black holes "evaporate" via Hawking radiation, then they cannot exist forever. So, from my external perspective, watching the person fall in, they slow down, freeze, and redshift to "nothing," but never cross the event horizon. Does the equivalence principle say my perspective is valid? If it does, is it possible that that person really never crossed the event horizon? The...
In this video I can see a person walking around lines of curvature on a sphere with an arrow strapped to his waist. His task is to keep the arrow pointed in the same direction How does he do this ? Does he use a reference point like the stars? (that only move very slowly) If that is how he keeps the arrow pointing in the same direction, is that equivalent to saying that he orients the arrow wrt the 3d space that the sphere is embedded in? So ,although one refers to intrinsic curvature...
ASSUMPTIONS 1. Two identical clocks A and B in the same inertial frame are stationary relative to each other a fixed distance L apart. Time passes at the same rate for both. 2. Both clocks are able to send/receive light signals and to write/read the send/receive times into signals. 3. The speed of light is anisotropic. METHOD 1. At time t[A1] and time t[B1], clock A sends a light signal to clock B. The clock B time is unknown to A. 2. Clock B receives the signal from A at time t[B2] and...
