LaTeX Easy Tips for Bold Text in LaTeX | Learn How to Bold Text in LaTeX
  • Thread starter Thread starter member 428835
    Latex
In this discussion, users seek assistance with bolding characters in LaTeX, specifically the Greek letter pi. The primary issue arises from the fact that \textbf only works in text mode, while \pi is typically used in math mode. Standard LaTeX does not support bold lowercase Greek letters directly, leading to suggestions to use packages like bm or amsbsy for bold symbols. A user points out that while it is possible to achieve bold math symbols using \boldmath, it affects all math in the equation and can complicate the formatting. Further exploration reveals that \boldmath is defined in LaTeX's base code but is not user-friendly for mixing bold and non-bold characters. The discussion concludes with reflections on LaTeX's design limitations, noting that its original architecture may not align with modern computing needs.
member 428835
hi pf!
can someone help me bold in latex. for some reason if i use \textbf{pi} if get ##\textbf {pi}## but if i use \textbf {\pi} i do not get a bold ##\pi## but only an error. i have also tried \bfseries and no luck.
please help! thanks!
\pi only works in math node, e.g. $\pi$. \textbf only works in text mode (as you might guess from the name).
But "standard" LaTeX doesn't have bold lower case Greek letters anyway, so you have to do something like
Code:
\usepackage{bm}
$\bm{\pi}$
or if you are using the AMS math package,
Code:
\usepackage{amsbsy}
$\boldsymbol{\pi}$
Likes member 428835
thanks a ton!
That's actually incorrect. All math symbols can be set in bold in LaTeX, but in very contrived way. You have to activate \boldmath, but then all math will be typeset in bold! The way around that is something like
Code:
\mbox{\boldmath $\pi$}
such that the \boldmath will only affect equations inside the mbox. If you want just one bold symbol in an equation, you have to use the awful construct
Code:
$2 \alpha \mbox{\boldmath $\beta$}$
LaTeX being so well thought out from a typographical point of view, I don't know why they messed up with bold.
Anyway, the conclusion is that it is better to use the additional packages you suggested.
After a bit of research, I agree with you. There are plenty of statements on (usually reputable) websites that \boldmath is "part of plain TeX". But it's not in the index of Knuth's TeXBook, and those statements seem to be wrong.
It is defined in the "base" TeX code of LaTeX. It's not quite obvious how it's defined but it looks like it redefines all the math font names to bold versions. That may not work with all math fonts, or with newer versions of TeX that handle fonts in a completely different way (e.g. direct access to Unicode and/or the internals of Open Type fonts).
And as you say, \boldmath is not nice to use, if you want to mix bold and non-bold characters in the same math formula.
It was very well thought out, and forward looking, when it was first released. But that was 36 years ago. With hindsight, too many implementation-specific details were hard-wired into it - like the fact that it was designed to run on 16-bit computer hardware, not 64-bit.
