CDF Query: Conditional CDF of S
  • Thread starter Thread starter nikozm
    Cdf Conditional
The discussion focuses on the conditional cumulative distribution function (CDF) of the random variable S, defined as S = a*X/(b*X+c), where a, b, and c are positive constants and X is a positive random variable. The user inquires whether the expression for the CDF of S, given another independent random variable H, is correct. A response clarifies that since S and H are independent, the conditional CDF F_{S|H} simplifies to the unconditional CDF F_{S}. Thus, the original expression holds true trivially. The discussion emphasizes the implications of independence in the context of conditional distributions.
nikozm
Hello.
I was wondering if the following is correct.
Let S= a*X/(b*X+c), where a,b,c are positive constants and X is a positive random variable. Also let H= h, where h is also a positive random variable (S and H are mutually independent).
Then, let F_{Z}(.) and f_{Z}(.) denote the CDF and PDF of Z, respectively. Thus, does the following holds true?
F_{S}(y) = ∫ F_{S|H}(a*X/(b*X+c) <= y | H) * f_{H}(h) dh.
Thank you in advance.
You say H and S are independent. In that case F_{S|H} = F{S}. Therefore the expression hold trivially.
I was reading documentation about the soundness and completeness of logic formal systems. Consider the following $$\vdash_S \phi$$ where ##S## is the proof-system making part the formal system and ##\phi## is a wff (well formed formula) of the formal language. Note the blank on left of the turnstile symbol ##\vdash_S##, as far as I can tell it actually represents the empty set. So what does it mean ? I guess it actually means ##\phi## is a theorem of the formal system, i.e. there is a...
