Change of the minkowski metric
ChrisVer
If I am not mistaken, the change of the minkowski metric to:
n_{\mu\nu} \rightarrow g_{\mu\nu}(x)
will violate the Poincare invariance of (example) the Electromagnetism Action.
However it allows us to define a wider set of arbitrary transformations (coordinate transformations).
The last line confuses me. If I can choose a general coordinate system without a problem (since everything will remain invariant) what restricts my choice not to be of the form:
x'^{a}(x^{b})= Λ^{a}_{b}x^{b}+p^{a}?
Nothing will prevent you from choosing that form of a transformation, if your Lambda matrix is arbitrary. What's special about the Poincare transformations is that the Lambda matrix has special properties (i.e. that it preserves the Minkowski metric). General coordinate transformations will not. Try a change from Cartesian coordinates to Polar coordinates and see what your lambda matrix has to be, and then notice that it is not in the group of Lorentz transformations.
The Poincare group consists of Lorentz transformations ((hyperbolic) rotations in spacetime
by ##\Lambda##) and spacetime translations by ##a \in \mathbb{R}^4##. Changing you coordinate system from one cartesian one to another one corresponds to letting the Poincare group act on your coordinate system via
$$x'^i=\Lambda^i{}_j x^j + a^i \, .$$
Since
$$\eta = \eta_{ij} \, d x^i \, dx^j$$
you will find that this transformation leaves the metric invariant. Note that I omitted the tensor product, because it is symmetric. Changing to another non-cartesian coordinate system does not (!) change your metric, however, it does change how it looks like in your coordinate system. The EM-field tensor is
$$F= F_{ij} \, d x^i \wedge d x^j$$
and things work in an entirely analogous manner.
You seem to be assuming that Minkowski coordinates still exist in GR. They don't (except in special cases). Therefore there is no way to define a Lorentz transformation.
Yes, if this is really a GR question, then you're thinking about this in an entirely wrong manner.
Let's get this straight: Special relativity is indeed a special case of general relativity. Spacetime in special relativity is ##(\mathbb R ^4 , \eta)##, where ##\mathbb R ^4## is your spacetime manifold and ##\eta## tells you implicitly how far points are from each other, angles and which directions are spacelike, timelike, lightlike/null, etc. The poincare group is the group of active (or passive if interpreted as coordinate transformations) transformations on your manifold that leave the metric ##\eta## the same.
In general relativity, we replace ##\mathbb R ^4## by a general 4-dimensional manifold ##Q## and the Minkowski metric ##\eta## by a general non-constant metric ##g##, which is a solution to the Einstein equation. Then the group of transformations that leaves ##g## invariant will not be the Poincare group. In fact, this group might not even exist. If it does, it is called an isometry group, because it doesn't change distances. Hence the Poincare group is the "largest" group of isometries of Minkowski spacetime.
Please read up on basic manifold theory, especially (pseudo-)Riemannian manifolds, before diving into GR.
OK, so this has bugged me for a while about the equivalence principle and the black hole information paradox. If black holes "evaporate" via Hawking radiation, then they cannot exist forever. So, from my external perspective, watching the person fall in, they slow down, freeze, and redshift to "nothing," but never cross the event horizon. Does the equivalence principle say my perspective is valid? If it does, is it possible that that person really never crossed the event horizon? The...
In this video I can see a person walking around lines of curvature on a sphere with an arrow strapped to his waist. His task is to keep the arrow pointed in the same direction How does he do this ? Does he use a reference point like the stars? (that only move very slowly) If that is how he keeps the arrow pointing in the same direction, is that equivalent to saying that he orients the arrow wrt the 3d space that the sphere is embedded in? So ,although one refers to intrinsic curvature...
ASSUMPTIONS 1. Two identical clocks A and B in the same inertial frame are stationary relative to each other a fixed distance L apart. Time passes at the same rate for both. 2. Both clocks are able to send/receive light signals and to write/read the send/receive times into signals. 3. The speed of light is anisotropic. METHOD 1. At time t[A1] and time t[B1], clock A sends a light signal to clock B. The clock B time is unknown to A. 2. Clock B receives the signal from A at time t[B2] and...
