Ignoring SSB in massless phi^4 theory
  • Thread starter Thread starter geoduck
    Massless Theory
geoduck
If a theory is spontaneously broken, you usually make calculations by expanding the field about the ground-state expectation value \nu, so that you define a new field \rho such that \phi=\nu+\rho such that \langle \rho \rangle =0.
What if you just calculate perturbation theory with \phi instead of the new field \rho?
It seems that massless \phi^4 is spontaneously broken at the 1-loop level. So do you have to do perturbation theory with the field \rho instead of \phi?
It is possible to do perturbation theory with the field \phi, however it is not necessarily the most accurate or efficient way to approach the problem. Expanding the field about the ground-state expectation value \nu by defining a new field \rho allows you to find the exact ground-state energy of the system as well as calculate the mass of the particle created due to the spontaneous breaking. This method is often thought of as the more effective way to approach the problem.
Not an expert in QM. AFAIK, Schrödinger's equation is quite different from the classical wave equation. The former is an equation for the dynamics of the state of a (quantum?) system, the latter is an equation for the dynamics of a (classical) degree of freedom. As a matter of fact, Schrödinger's equation is first order in time derivatives, while the classical wave equation is second order. But, AFAIK, Schrödinger's equation is a wave equation; only its interpretation makes it non-classical...
Insights auto threads is broken atm, so I'm manually creating these for new Insight articles. Towards the end of the first lecture for the Qiskit Global Summer School 2025, Foundations of Quantum Mechanics, Olivia Lanes (Global Lead, Content and Education IBM) stated... Source: https://www.physicsforums.com/insights/quantum-entanglement-is-a-kinematic-fact-not-a-dynamical-effect/ by @RUTA
Is it possible, and fruitful, to use certain conceptual and technical tools from effective field theory (coarse-graining/integrating-out, power-counting, matching, RG) to think about the relationship between the fundamental (quantum) and the emergent (classical), both to account for the quasi-autonomy of the classical level and to quantify residual quantum corrections? By “emergent,” I mean the following: after integrating out fast/irrelevant quantum degrees of freedom (high-energy modes...
