Looking for fast electronically controlled valve
  • Thread starter Thread starter zakzackzachary
    Valve
The discussion centers on finding a fast electronically controlled valve suitable for a mechanical thesis on vortex rings in fluid. The desired specifications include a diameter of 0.5"-1.0", the ability to operate with water at 20°C, and open/close times within 500 ms, all within a budget of $1000. Participants suggest standard ball valves for their quick response times and explore options like solenoid valves and Burkert valves, which offer easier control accessories. The conversation also touches on integrating these valves with a National Instruments DAQ and LabView for computer control. Overall, the focus is on sourcing high-quality, responsive valves for academic research.
zakzackzachary
Hi all, I'm new to this forum, but have used it before for school. I'm currently working on my MS mechanical thesis which pertains to vortex rings in fluid.
I was wondering if anyone had any good websites/suggestions for an electronically controlled valve with the following specifications:
  • can be used with water at about 20°C
  • diameter of 0.5"- 1.0"
  • electronically controlled, preferably with a timer so I can generate consistent pulses
  • open/close within 500 ms (0.5 sec)
  • able to withstand a 6 ft pressure head (most should do this no problem)
  • budget of about $1000
Obviously my budget is high, so a high quality valve would be nice. I've looked through McMaster-Carr and Alibaba, and am going to continue my research, but just thought I'd see if anybody had any input.
Thanks in advanced!
Zachary
(PS. Sorry if this is the wrong forum)
Welcome back to PF.
The fastest full flow valves I have found are standard ball valves since they only require a 90° rotation. Transition times are less than 100ms when controlled by DC servo motors.
Pneumatically controlled ball valves are available for the industrial market.
Okay great, the speed the valves open and close usually isn't mentioned in the specs. I've been chatting with customer service.
Is it modulating or two position? If two position, how about a solenoid valve?
Two position, and a solenoid would be great! That's what I'm looking into now.
Okay, I wanted to update this thread in case someone digs it up in a Google search or something.
I found a couple websites to check out including "www.ascovalve.com" , but am currently looking at some Burkert valves since they seem to have some easier control accessories.
So I've got this http://www.iprocessmart.com/Merchant2/merchant.mvc?Screen=CTGY&Category_Code=4021T5281 and am currently looking at the accessories to hook up to it in order to be able to open/close (read: control) it from a computer.
It looks like even the Burkert valves are somewhat industrial so I'm going to be looking into possibly utilizing a more often-used-at-universities-standard National Instruments DAQ and then use some sort of LabView like control interface.
How did you find PF?: Via Google search Hi, I have a vessel I 3D printed to investigate single bubble rise. The vessel has a 4 mm gap separated by acrylic panels. This is essentially my viewing chamber where I can record the bubble motion. The vessel is open to atmosphere. The bubble generation mechanism is composed of a syringe pump and glass capillary tube (Internal Diameter of 0.45 mm). I connect a 1/4” air line hose from the syringe to the capillary The bubble is formed at the tip...
Thread 'Physics of Stretch: What pressure does a band apply on a cylinder?'
Scenario 1 (figure 1) A continuous loop of elastic material is stretched around two metal bars. The top bar is attached to a load cell that reads force. The lower bar can be moved downwards to stretch the elastic material. The lower bar is moved downwards until the two bars are 1190mm apart, stretching the elastic material. The bars are 5mm thick, so the total internal loop length is 1200mm (1190mm + 5mm + 5mm). At this level of stretch, the load cell reads 45N tensile force. Key numbers...
I'd like to create a thread with links to 3-D Printer resources, including printers and software package suggestions. My motivations are selfish, as I have a 3-D printed project that I'm working on, and I'd like to buy a simple printer and use low cost software to make the first prototype. There are some previous threads about 3-D printing like this: https://www.physicsforums.com/threads/are-3d-printers-easy-to-use-yet.917489/ but none that address the overall topic (unless I've missed...
