Simplifying Difference Quotients with Variable Expressions - How to Solve?
To solve the difference quotient for the function f(x) = (5x)/(x-1), first substitute a into the function to find f(a) = (5a)/(a-1) and then substitute a + h to find f(a + h) = (5(a + h))/((a + h) - 1). The difference quotient is calculated as (f(a + h) - f(a))/h. It's important to use parentheses correctly during substitution to avoid confusion. Properly substituting the expressions will clarify the calculations needed to solve the problem.
Niaboc67
Find f(a), f(a + h),and the difference quotient f(a + h) − f(a), h where h ≠ 0.
f(x) = 5x/x-1
f(a) = ?
f(a + h) = ?
f(a + h) − f(a)/(h) = ?
As I understand it I must substitute the values but I don't understand the question. say if it were something like 1/x I would know to fill it into (1/(x+h)-1/x) / h
But this just confuses me I don't know how to answer these questions
f(x) = 5x/x-1
f(a) = ?
f(a + h) = ?
The way you wrote it you have
f(x) = \frac{5x}{x} - 1 = 5 - 1 = 4
so ##f(a) = f(a+h) = 4##. Perhaps you really did not mean what you wrote, but because you failed to use parentheses it is impossible to say. And, of course, you wrote
f(a+h) - \frac{f(a)}{h} = 4 - \frac{4}{h}.
Again, maybe you meant something different.
What I meant was: f(x) = (5x)/(x-1) my mistake
Just replace every instance of x with the given value. Where the given value consists of an expression, like a+h, put the expression in parentheses when making the substitution.
I tried to combine those 2 formulas but it didn't work. I tried using another case where there are 2 red balls and 2 blue balls only so when combining the formula I got ##\frac{(4-1)!}{2!2!}=\frac{3}{2}## which does not make sense. Is there any formula to calculate cyclic permutation of identical objects or I have to do it by listing all the possibilities? Thanks
