Is my formula for piston height and velocity in an engine correct?
  • Thread starter Thread starter Townsend
    Engine Model
The discussion focuses on a mathematical formula for calculating the height of a piston above the crankshaft center based on the crankshaft radius and connecting rod length. The formula presented is f(x)=asin(x)+b√((1-a²cos²(x))/b²), which is differentiated to find the change in height with respect to the angle. The velocity of the piston is derived from this height function, incorporating RPM to express speed in length per minute. Feedback indicates that the formula is largely correct, with only minor typographical errors noted. Overall, the calculations and approach to determining piston height and velocity are validated by another contributor.
Townsend
I wasn't sure of where this question is best suited but since my interest is only mathematical I figured this is a good forum.
Using vectors I came up with a formula for the height of a piston above the center of the crankshaft for any given angle x (in radians). I set an x,y coordinate system with the origin at the center of the crank. With x=0 radians the crankshaft has the lower end of the connecting rod along the positive x-axis.
So if a is the radius of the crankshaft and b is the length of the connecting rod we have
<br /> f(x)=asin(x)+b \sqrt{ \frac{1-a^2cos^2(x)}{b^2} } <br />
So if that formula is correct then if I differentiate it I should have a formula for the change of height with respect to any given angle. This is
<br /> f&#039;(x)= \frac{a^2*b*sin(x)*cos(x)}{ \sqrt{ b^2-a^2*cos^2(x) }} +a*cos(x) <br />
So to get the velocity I need to take \frac{f&#039;*2 \pi*t}{minute} where t is any given rpm.
So if I did everything correctly I should be able to find the speed in units of length per minute of the piston for any given rpm t.
So did I make any mistakes so far? Or does everything seem ok?
Thanks for your time...
Mathematics news on Phys.org
Apart from two typos, both involving b, your working is OK.
I derived the eqn for the piston speed using a different method and got the same eqn as yourself, so that provides some confrmation.
Insights auto threads is broken atm, so I'm manually creating these for new Insight articles. In Dirac’s Principles of Quantum Mechanics published in 1930 he introduced a “convenient notation” he referred to as a “delta function” which he treated as a continuum analog to the discrete Kronecker delta. The Kronecker delta is simply the indexed components of the identity operator in matrix algebra Source: https://www.physicsforums.com/insights/what-exactly-is-diracs-delta-function/ by...
Suppose ,instead of the usual x,y coordinate system with an I basis vector along the x -axis and a corresponding j basis vector along the y-axis we instead have a different pair of basis vectors ,call them e and f along their respective axes. I have seen that this is an important subject in maths My question is what physical applications does such a model apply to? I am asking here because I have devoted quite a lot of time in the past to understanding convectors and the dual...
