Solve Binomial Identities to Approximate Fresnel Zone Radius
The discussion focuses on deriving the Fresnel zone radius approximation using the binomial theorem and Taylor series. A user expresses confusion over a mathematical jump in the derivation, specifically regarding the transition from (D^2 + r^2)^(1/2) to D(1 + (r^2)/(D^2))^(1/2). The conversation highlights the Taylor series approximation, where the second term is retained to simplify the expression. The Taylor series is explained as a way to represent differentiable functions as an infinite sum of terms based on their derivatives at a single point. The thread concludes with a request for further clarification on the Taylor series derivation.
mezarashi
I was going the derivations for Fresnel zone radius approximation, and there was a jump in the math which I don't fully understand. If someone could take a look at this and help me figure. I was hinted that it had to do with the binomial theorem, but I have no idea >.<
Seems like LaTeX isn't working -_-
(D^2 + r^2)^(1/2)
if r << D
( D^2( 1 + (r^2)/(D^2) ) )^(1/2)
D1 + (r^2)/(2D^2) <--- ?
Mathematics news on Phys.org
Let's set this in Latex:
(D^{2}+r^{2})^{\frac{1}{2}}=D(1+\epsilon)^{\frac{1}{2}}, \epsilon=(\frac{r}{D})^{2}
If we now have \epsilon&lt;&lt;1, we have, by retaining the second term of the Taylor series about \epsilon=0:
(1+\epsilon)^{\frac{1}{2}}\approx{1}+\frac{\epsilon}{2}
Thus, you have:
(D^{2}+r^{2})^{\frac{1}{2}}\approx{D}+\frac{r^{2}}{2D}, \frac{r}{D}&lt;&lt;1
Hey awesome, thanks. Oh and Latex is working :P
Could you tell me a bit more about this "Taylor series" approximation or a link to its derivation, although I know this is true by punching some test numbers in the calculator. Thanks again.
Okay, about Taylor series:
You know that given f(x) differentiable, you may write it as:
f(x)=f(0)+\int_{0}^{x}f&#039;(t)dt(1)
Now, use partial integration on the integral in the following manner:
\int_{0}^{x}f&#039;(t)dt=(t-x)f&#039;(t)\mid_{t=0}^{t=x}-\int_{0}^{x}(t-x)f&#039;&#039;(t)dt(2)
We also have:
(t-x)f&#039;(t)\mid_{t=0}^{t=x}=0*f&#039;(x)+xf&#039;(0)=xf&#039;(0)
thus, (2) may be written as:
f(x)=f(0)+f&#039;(0)x+\int_{0}^{x}(x-t)f&#039;&#039;(t)dt(3)
where I have drawn the minus sign underneath the integral sign.
We may now rewrite (3) by noting:
\int_{0}^{x}(x-t)f&#039;&#039;(t)dt=\frac{x^{2}}{2!}f&#039;&#039;(0)+\frac{1}{2!}\int_{0}^{x}(x-t)^{2}f&#039;&#039;&#039;(t)dt
that is:
f(x)=f(0)+f&#039;(0)x+\frac{f&#039;&#039;(0)}{2!}x^{2}+\frac{1}{2!}\int_{0}^{x}(x-t)^{2}f&#039;&#039;&#039;(t)dt(4)
The emerging series has the form, for an infinitely differentiable function:
f(x)=\sum_{n=0}^{\infty}\frac{f^{(n)}(0)}{n!}x^{n}
where n! is the factorial 1*2*3...*n (0!=1), and f^{(n)} denotes the n'th derivative of f. (f is considered its own 0'th derivative).
That infinite series is called the Taylor series of f with respect to 0, a finite, truncated version of it is called a Taylor series approximation to f.
If we have the identity containing f(x) on the left-hand side and a finite sum and the integral on the right-hand side (for example our (4)), we call the integral "the remainder", or "error term".
Thread 'Video on imaginary numbers and some queries'
Hi, I was watching the following video. I found some points confusing. Could you please help me to understand the gaps? Thanks, in advance! Question 1: Around 4:22, the video says the following. So for those mathematicians, negative numbers didn't exist. You could subtract, that is find the difference between two positive quantities, but you couldn't have a negative answer or negative coefficients. Mathematicians were so averse to negative numbers that there was no single quadratic...
Insights auto threads is broken atm, so I'm manually creating these for new Insight articles. In Dirac’s Principles of Quantum Mechanics published in 1930 he introduced a “convenient notation” he referred to as a “delta function” which he treated as a continuum analog to the discrete Kronecker delta. The Kronecker delta is simply the indexed components of the identity operator in matrix algebra Source: https://www.physicsforums.com/insights/what-exactly-is-diracs-delta-function/ by...
Thread 'Unit Circle Double Angle Derivations'
Here I made a terrible mistake of assuming this to be an equilateral triangle and set 2sinx=1 => x=pi/6. Although this did derive the double angle formulas it also led into a terrible mess trying to find all the combinations of sides. I must have been tired and just assumed 6x=180 and 2sinx=1. By that time, I was so mindset that I nearly scolded a person for even saying 90-x. I wonder if this is a case of biased observation that seeks to dis credit me like Jesus of Nazareth since in reality...
