Minimizing the area in a parabola
  • Thread starter Thread starter r3dxP
    Area Parabola
The discussion revolves around finding the point on a parabola defined by the function f(x) = 6 - x², such that the area of a triangle formed by the coordinate axes and the tangent line to the parabola is minimized. Participants are exploring the relationship between the parabola and the tangent line, as well as how to express the area of the triangle as a function of a variable point on the parabola.
  • Exploratory, Mathematical reasoning, Problem interpretation
  • Participants discuss deriving the equation of the tangent line at a point on the parabola and how to express the area of the triangle as a function of that point. Questions arise regarding the correct formulation of the tangent line and the area calculation.
Some participants have provided guidance on deriving the tangent line and formulating the area function, while others are questioning their approaches and the correctness of their results. There is an ongoing exploration of the relationship between the variables involved and the area function.
Participants are working under the constraints of a homework assignment, which may limit the information they can use or the methods they can apply. There is also a focus on ensuring that the mathematical expressions used are correctly formulated without introducing errors.
r3dxP
Let f(x) = 6-x^2 for 0<w<sqrroot(6); let A(w) be the area of the triangle formed by the coordinate axes and the line tangent to the graph of f.
see figure : http://img472.imageshack.us/img472/50/a5nt.jpg
Okay, I looked at your picture and read your post. There is no question there! I can guess from the title that the problem is to find the point on the parabola such that the triangle constructed has minimum possible are- though that is NOT "minimizing the area in a parabola"!
Have you done anything at all on this? In particular, taking the "x" coordinate of the point on the parabola as fixed (call it x0, say) can you write the equation of the tangent line there?
Once you have that, you should be able to write the equation for the area of the triangle as a function of x0.
yea i did try it like 20x but couldn't figure it out..
i derived to get the tangent line, so slope = -2x at point x..
so i find the equation for the line.. thus finding b as 6+x^2
i got this by plugging (x,6-x^2) into the equation y = -2x(x) + b and solved for b.
then i get the final equation of y = 6-x^2! i end up where i started from! what is going on?!
The equation for a tangent line to a curve f(x) at a point (a,b) is given by y-b = f'(a)(x-a). Note that with f'(a), I mean the derivative of f(x) evaluated in the point (a,b) so with x = a.
So instead of (a,b), you know have the general point (p,6-p²). You already had the derivative, so can you know get to the tangent line for a general point on the parabola? It's just filling in.
After that, how would you find the area of the triangle? You're "lucky" since it's a right triangle ;)
if i just find the tangent line equation, i end up with y=6-x^2 as my line of my tangent line. Is that suppose to be right?
and how am i suppose to find the minimum area under the triangle and prove that its the smallest possible area of the triangle on the parabola function that's given?
In the equation I gave you, don't fill in (x,6-x²) since x is also your unknown in the equation, your variable! Instead, use (e.g.) (p,6-p²). Just apply the formula I gave. Then, for every p, you get a point (p,6-p²) on the parabola with the tangent line you just set up, p being substituted with the value in question.
so.. y-(6-p^2) = f'(p) * (x - p)
y - 6 + p^2 = -2p (x-p)
y = p^2 -2px + 6 ? what does this mean? the equation of the tangent line?
Correct, for every p you fill in, you'll now get the tangent line to the parabola at the point x = p, y = 6-p^2.
ok, so.. what i did was.. set 0=-2px + p^2 + 6, then solved for x. x= (p^2+6)/2p;
where as the y-intercept is (0, p^2 +6)
so to get the area.. A(p) = 1/2 * (p^2+6)/2p * (p^2+6)
A(p) = (p^4 + 12p^2 + 36) / 4p
I derive this area to find the min/max..
am i on the right track?
Yes, that looks good.
One advice though. It's generally easier (in my opinion) to not expand the brackets. So just keep A(p) look like:
A(p)=\frac{(p^2+6)^2}{4p}
Taking the derivative will be easier in this form
thanks a lot.. i got A'(w) = 0 where w=-6 and 2.
thus A(2) = 12.5; which is the min point I am guessing.
i can check the value of A''(2) to see if its <0 or >0 to det. if its min or max but I am too lazy. i think i did this right right now. once again, thank you all for the help.
