1 dimensional heat transfer question
5 replies · 2K views · last reply
theBEAST
Problem statement with equation (T - T1)/(T2 - T1) = C1 + C2x^2 + C3x^3 for a plane wall, the answer S = So - (3So/L - 6k(T1 - T2)/L^3) x, and a diagram of a wall of thickness L with T1 on the left face, T2 on the right face and an arrow labelled x.
d/dx(kdT/dx) + S = 0 (for steady state)
q_cond = -kAdT/dx
q_gen = S*Vol
Handwritten derivation on lined paper: boundary conditions T=T1 at x=0 and T=T2 at x=L, a cubic temperature profile T = (T2-T1)[C2x^2+C3x^3]+T1, its derivative dT/dx, and q_gen = q_cond = -kA dT/dx leading to S0L = -kA(T2-T1)[2C2x+3C3x^2], with a note that at x=0 this gives S0L=0 marked with question marks.
So I tried to equate q_cond to q_gen but it seemed to give me the wrong answer. Does anyone know why? I believe to get the right answer I have to use the first equation I wrote in the relevant equations section.
Does my method not work because S is not uniform? But then it tells me that at x = 0, S = So so it shouldn't matter since we have a boundary condition?
The quick reply would be that there is no reason to equate q_cond to q_gen: there are two mechanisms that cause temperature change, namely conduction and heat generation. The sum of the contributions to dT/dt has to cause a steady state, hence the = 0.
Could you also check q_gen = S * Vol ? This looks too much as if S is constant all over the place.
Hmm, I am not too sure about the equations you use for S, but I think you need to do something about the constants, C2 and C3 as well.
I would suggest looking at the boundary conditions. You have already been given an expression for the temperature, which you solved correctly. When T=T2 you get 1 (as you also did).
But the deriviative of the equation also has to be continuous over the boundary. (Note: can you explain why?)
You then have 2 equations with 2 unknowns. Remember that at this boundary x=L! (which you also wrote down).
So you could then express the constants C2 and C3 in terms of L. I think that is what you should start by doing.
EDIT: I solved it now (phew), but the equation you need would be:
$$ \frac{d^2T}{dx^2}+\frac{S}{k}=0 $$
Are you familiar with this expression, or?
This is exactly the same equation you wrote down (correctly) in your original post. So you shouldn't be too surprised that it gives you the right answer.
But not the one used in the attached paper :-) but yeah, then you must be familiar with it!
