100 hotel rooms and 100 guests?
  • Thread starter Thread starter mimibajiduh
In this discussion, participants analyze a scenario involving 100 hotel rooms and 100 guests who change the status of each room based on a specific pattern. Each guest toggles the status of rooms at intervals corresponding to their guest number, leading to a focus on the factors of each room number. It is concluded that rooms with an odd number of factors, specifically the square numbers (1, 4, 9, 16, 25, 36, 49, 64, 81, 100), will be closed if all rooms start open. The conversation emphasizes understanding the relationship between room numbers and their factors to determine the final status of each room. Ultimately, the analysis confirms that only the square-numbered rooms will remain closed.
mimibajiduh
there are 100 hotel rooms and 100 guests.
change the status means open goes to closed and closed goes to open.
guest 1: goes to every room and changes its status
guest 2: goes to every 2 rooms(2, 4,6,8,...,100) and changes its status
guest 3: goes to every 3 rooms and changes its status
guest 4: goes to every 4 rooms and changes its status
this goes on all the way to guest 100
guest 100: goes to 100 and changes its status
which rooms are closed? i know that room 1 is closed.
hi mimibajiduh! :smile:
take rooms 10 20 30 and 60 as examples …
how many guests visit each of those rooms? :wink:
I remember this question from my gr.7 class and I remember writing like huge essay to explain it. Let's see if i can do it in few lines. So, you have 100 rooms. or essentially 100 numbers. Then think about factors of each number. So let's say 8 for example factors are: 1, 2, 4, 8.
Now think about pairs: 1 x 8 = 8 and 2 x 4 = 8.
basically all of the numbers are pairs. Except 10 of them; namely squares: 1,4,9,16,25,36,49,64,81,100... By that i mean consider factors for 36 =>
1 x 36 = 36
2 x 18 = 36
3 x 12 = 36
4 x 9 = 36
BUT:
6 x 6 = 36
Hopefully you get the idea.
1 x 36 = 36
2 x 18 = 36
3 x 12 = 36
4 x 9 = 36
BUT:
6 x 6 = 36
hey utkarsh 1 , i am utkarsh009, what a coincidence!
first tell me what was the original status of all the rooms and also whether the guests have to change the status of their room for coming out?
now, let me just explain what you said in my words. just see if i am correct or not.
the the numbers which have even number of factors have the same status and the ones with odd number of factors have same status.
if the original status was that all the rooms were opened then the square numbers (which have odd number of factors) will be closed.
just check whether i am right or not?
Yes its correct! Probably better explained since its more concise
thank you very much !
I tried to combine those 2 formulas but it didn't work. I tried using another case where there are 2 red balls and 2 blue balls only so when combining the formula I got ##\frac{(4-1)!}{2!2!}=\frac{3}{2}## which does not make sense. Is there any formula to calculate cyclic permutation of identical objects or I have to do it by listing all the possibilities? Thanks
Since ##px^9+q## is the factor, then ##x^9=\frac{-q}{p}## will be one of the roots. Let ##f(x)=27x^{18}+bx^9+70##, then: $$27\left(\frac{-q}{p}\right)^2+b\left(\frac{-q}{p}\right)+70=0$$ $$b=27 \frac{q}{p}+70 \frac{p}{q}$$ $$b=\frac{27q^2+70p^2}{pq}$$ From this expression, it looks like there is no greatest value of ##b## because increasing the value of ##p## and ##q## will also increase the value of ##b##. How to find the greatest value of ##b##? Thanks
