Producing 100HZ Signal: A Story of Challenges and Creative Solutions
  • Thread starter Thread starter m.s.j
    Signal
An electromotor serviceman attempted to produce a 100HZ signal using an old 50HZ generator by modifying the armature windings and adding a mid-pass filter. Despite his efforts, the output voltage remained distorted and did not yield a clean 100HZ signal due to harmonic complications. The discussion highlights that simply changing the stator was insufficient, and doubling the shaft speed could have been a more effective solution. Additionally, electromagnetic laws indicate that the nature of magnetic flux prevents the generation of even harmonics like 100HZ. Ultimately, the serviceman's approach failed because of the inherent limitations in the generator's design and the physics of magnetic fields.
m.s.j
One electromotor serviceman who worked in a small workshop needed an ac power supply with 100HZ frequency.
He knew that in synchronous generator, if the magnetic flux of the field system is distributed perfectly sinusoidal around the air gap, then e.m.f generated in each full-pitched armature coil will be sinusoidal completely.
He had an old and small 50HZ generator. He decided to use it for 100HZ signal producing.
For this purpose, he changed standard distributed windings of armature that located in stator slots. Also he connected one electronically mid-pass filter which tuned with 100HZ frequency in generator output.
The output voltage of generator was not sinusoidal and it is distorted by new space flux distortion. He had a lot of harmonics in output stage of generator, but he never observed 100HZ signal in filter output.
He more and more tried and changed the stator winding distribution frequently, but he couldn't to produce purposed signal.
Why? Why couldn't he?
BEST REGARDS
MSJ
Creative thinking is enjoyable,Then think about your surrounding things and other thought products. http://electrical-riddles.com
Since this question is on the riddles link, I'll guess it isn't homework.
While multipole design is not a strong point a couple things come to mind.
1) You need to double the winding count. It seems improbable that there would be enough slots.
2) You can't change just the stator as the question states.
3) The simple solution would have been to double the shaft speed.
According to electromagnetic laws, the curl of electrical field (E) must be zero, for the circulation is zero, and the curl of magnetic field (H) is not zero, however; its circulation per unit area is the current density by Ampere's circuital law.Therefor in all magnetic systems, if some magnetic flux lines export from a surface of one volume of space, then same flux lines import to that volume via its other surfaces.
It means, for mathematic function of magnetic flux we can write: f(-x) = f(x) that named odd function.
Also according to Fourier analysis, each periodical odd function can be written with the sum of odd harmonic elements. So the serviceman can never produce even harmonic flux ( 100HZ,200HZ,…) in generator gap.
BEST REGARDS
MSJ
That sentence shall be corrected as follows:
It means, for mathematic function of magnetic flux we can write: f(-x) = - f(x) that named odd function. Also because of core symmetrical construction, the flux function can be written by f ( x ) = f ( L – x ) where 2L is the function period.
REGARDS
MSJ
Hi all I have some confusion about piezoelectrical sensors combination. If i have three acoustic piezoelectrical sensors (with same receive sensitivity in dB ref V/1uPa) placed at specific distance, these sensors receive acoustic signal from a sound source placed at far field distance (Plane Wave) and from broadside. I receive output of these sensors through individual preamplifiers, add them through hardware like summer circuit adder or in software after digitization and in this way got an...
While I was rolling out a shielded cable, a though came to my mind - what happens to the current flow in the cable if there came a short between the wire and the shield in both ends of the cable? For simplicity, lets assume a 1-wire copper wire wrapped in an aluminum shield. The wire and the shield has the same cross section area. There are insulating material between them, and in both ends there is a short between them. My first thought, the total resistance of the cable would be reduced...
I am not an electrical engineering student, but a lowly apprentice electrician. I learn both on the job and also take classes for my apprenticeship. I recently wired my first transformer and I understand that the neutral and ground are bonded together in the transformer or in the service. What I don't understand is, if the neutral is a current carrying conductor, which is then bonded to the ground conductor, why does current only flow back to its source and not on the ground path...
