1994 Physics Olympiad Semi-Final Exam Question
The discussion centers on analyzing the time it takes for water to pour out of a can through holes of varying diameters and water heights. The experiment utilized five cylindrical containers, measuring the time taken to empty them through circular openings of different sizes. Key findings indicate that the time can be expressed as a function of both the height of the water and the diameter of the hole, leading to the equation y = k * h^1/2 * d^-2. Participants also explored the logarithmic relationships between these variables, suggesting that the time behavior aligns with theoretical predictions.
  • Understanding of fluid dynamics principles
  • Familiarity with logarithmic and semi-logarithmic graphing techniques
  • Basic calculus concepts, particularly logarithmic functions
  • Experience with data analysis software such as Excel or Kaleidagraph
  • Learn how to perform curve fitting in Kaleidagraph for experimental data
  • Study the derivation of fluid flow equations in physics
  • Investigate the impact of varying hole diameters on flow rates
  • Explore the relationship between experimental error and data accuracy in physics experiments
Students and educators in physics, particularly those focusing on fluid dynamics and experimental design, as well as researchers analyzing time-dependent fluid flow behaviors.
HPphysics
An experiment was conducted to investigate the time it takes water to pour out of a can through a little hole and the amount of water in the can. To find the dependence on the size of the hole, five large cylindrical containers of water of the same size were emptied through relatively small circular openings of different diameter. To find the dependence on the amount of water the same containers were filled to different heights.
Each measurement was repeated several times using a handheld stopwatch to measure the times to the nearest 1/10th of a second. The averages of the times are recorded in the following table.
Height cm​
Diameter (cm)
30 15 8 4 1​
1.5
97.4 sec 68.9 sec 50.3 sec 35.6 sec 17.8 sec​
2.0
54.8 sec 38.7 sec 28.3 sec 20.0 sec 10.0 sec​
3.0
24.3 sec 17.22 sec 12.6 sec 8.9 sec 4.4 sec​
4.0
13.7 sec 9.7 sec 7.1 sec 5.0 sec 2.5 sec​
5.0
8.8 sec 6.2 sec 4.5 sec 3.2 sec 1.6 sec​
Find the relationship between the time and:
a) the height of the water in the can
b) the diameter of the hole
c) using the results of a) and b), formulate a general expression for the time y as a function of both the diameter and the height
d) Use the expression from c) to predict the time required to empty a can with a 3.5cm diameter to a height of 20cm
Knowledge of log-log and semi-log graphs..
a) We plotted a graph using a constant diameter (8cm) of time vs. height.
Time on y-axis and height on x axis. The graph appeared to be logarithmic, so we linearized the graph by log"ing each side. Our equation: y=.5logx+b
b) We basically did the same thing as question a, using a constant height (8cm) and plotting time vs. diameter. Our equation: y=-2logx+b
c) Our answer is y=kh^1/2d^-2 We are not exactly sure what our reasoning is
d) We aren't sure about c) so we haven't ventured here yet
Welcome to physics forums!
Do you perhaps see a relationship more simple than logarithms?
Hint:
What happens to the time if you quadruple the height?
What happens to the time if you double the diameter?
(Make sure to check these relationships in different cases, not just the easy case that I hinted at)
In general, I suggest using the variable names instead of x and y when quoting the equations you get.
So, you have deduced the following;
a) For constant diameter, you have ##\log(T(h,d)) = \frac 12 \log(h) + C_1(d)##. Note that the constant in general will depend on ##d##.
b) For constant height, you have ##\log(T(h,d)) = - 2 \log(d) + C_2(h)##.
For (c), ask yourself what the functions ##C_1## and ##C_2## could be such that ##T(d,h)## is the same for both expressions - then solve for ##T##.
Bonus problem: Can you argue for why the time behaves like this?
@orodruin
We still aren't sure what to do. We're thinking of graphing both expressions and finding the intersection point of the two lines. Would that serve any purpose? Not exactly sure how to find out what C1 and C2 should be.. We are only in our first year of calculus
Are you allowed to use a graphics package such as Excel or Kaleidagraph? If so, make a plot of t vs h for each of the five diameters on a single plot. Change the scale on each of the axes to be logarithmic. Use the curve fitting capabilities to get the equation for each of the five lines in the form t = k hn. In Kaleidagraph, this is the "power" fit option. The parameter n should come out to 0.5. Next plot the parameter k as a function of the hole diameter d. Again, change the scales to logarithmic, and fit the data in the form k = C dm. The parameter m should come out to -2. The curve fit will give you the value of the parameter C. So, combining these results, you get t = Chndm. You know the parameter C so, you are done. The equation should fit all the data.
Chet
HPphysics said:
@orodruin
So the expressions for ##T(h,d)## has to be equal, this tells you that
\frac 12 \log(h) + C_1(d) = -2 \log(d) + C_2(h).
Note that ##C_1## cannot depend on ##h## and ##C_2## cannot depend on ##d##. Both sides must show the same behavior with both variables in order to be equal so ##C_1## must have the same behavior with ##d## as the right-hand side does and so on. Therefore
C_1(d) = -2\log(d) + C, \quad C_2(h) = \frac 12 \log(h) + C.
So, in essence
\log(T(h,d)) = \frac 12 \log(h) - 2 \log(d) + C.
You can now solve for ##T##, what do you obtain?
Plotting in the same graph really does not add much information.
On a separate note: Are you sure you quoted the units in the table correctly? I find it hard to imagine a 5 cm hole in a 1 cm high cylinder as a "small hole". The data also seems to fit a bit too well with the logarithmic behavior to be from a real experiment (this can be checked but really is out of the scope for the question), it is likely mock data.
How would you generate data for a test so as they give the desired fitting parameters? I do not think you would perform an experiment and measure... :-p
ehild
ehild
I would add a random normal distributed number to each data point with a standard deviation the size of a reasonable experimental error. This way nasty physicists with a statistical mind set will not complain about my mock data on internet forums. :-p
I would not bother those far-away nasty physicists.:devil:
I used to include errors in my test examples but they were linear relations, it was easy.
ehild
Plot C1 vs d using log scales for both and see what you get.
Chet
34K
