1st year calc. trig, and inequalities
This discussion focuses on solving two calculus problems: proving the identity \( \frac{1}{1+\cot^2 X} = \sin^2 X \) and solving the inequality \( x^3 < \frac{x}{9} \). The first problem can be approached by using the identity \( \cot X = \frac{\cos X}{\sin X} \) to manipulate the equation into a known identity. The second problem involves factoring and applying the wavy curve method to determine the solution set, which is \( (x \leq -\frac{1}{3}) \cup (0 \leq x \leq \frac{1}{3}) \).
  • Understanding of trigonometric identities, specifically cotangent and sine functions.
  • Familiarity with polynomial inequalities and factoring techniques.
  • Knowledge of the wavy curve method for analyzing polynomial sign changes.
  • Basic skills in manipulating algebraic expressions and solving inequalities.
  • Study trigonometric identities and their proofs, focusing on cotangent and sine relationships.
  • Learn about polynomial inequalities and the wavy curve method in detail.
  • Practice solving cubic inequalities and sketching their graphs to identify roots.
  • Explore advanced techniques in calculus, such as Rolle's Theorem and its applications.
Students in introductory calculus courses, educators teaching trigonometry and inequalities, and anyone seeking to improve their problem-solving skills in mathematics.
m0286
Hi!
Im stuck on 2 assignment questions and I was hoping to get help on whut I am doing wrong. Its 1st year Calculus
1) It says Given a right angled triangle prove that 1/1+cot^2 X=sin^2 X
so I know cot=1/tan so 1/tan= 1/(opp/adj) therefore cot=1/(opp/adj) so 1/cot become (this is where it gets messy) opp/adj..?? i think since cot=1/(opp/adj) =adj/opp so 1/cot youd flip it again so opp/adj? And sin is opp/hyp .. so I am confused how does 1+opp/adj=opp/hyp ... or is that just it and it doesnt??
2) is *Solve the given inequalities giving the solution set of each s an interval or as a union of intervals. x^3 <x/9 so I've tried and tried I don't know how to solve this one. I've tried bringing x/9 to the other side and find a common denominator but that gives (9x^3-x)/9... and I don't know how to get x on one side and the numbers onthe other... especially since there is an x and a x^3... Is there a set of rules or something I am forgetting... I also tried mult. both sides by 9 9x^3<x.
For 1) you should use the fact that cot(x)= cos(x) / sin(x) instead of the adjacent/opposite stuff. Then try to manipulate the given equation to look like an identity that you already know.
SBRH
x^3 < x/9
Multiply both sides by 9 and move the term on the right:
9x^3 - x < 0
Thus..
x(9x^2 - 1) < 0
And factorizing further...
x(3x + 1)(3x - 1) < 0
You can go on from there. :)
Pseudo's method is a good one, but you need to sketch a cubic for the last part (not difficult in itself).
Here's another method.
x^3 \leq \frac{x}{9}
First check that x = 0 is a solution, it is.
Now divide out by x. Separate into two cases.
Case 1 (x positive)
x^2 \leq \frac{1}{9}
0 &lt; x \leq \frac{1}{3}
Adding the solution x = 0,
Case 2 (x negative)
x^2 \geq \frac{1}{9}
x \leq -\frac{1}{3}
So the full solution set is (x \leq -\frac{1}{3}) \cup (0 \leq x \leq \frac{1}{3})
For the first problem, I would be inclined to change everything to sine and cosine.
cot x= \frac{cos x}{sin x}[/itex] so \frac{1}{1+ cot^2 x}= \frac{1}{1+ \frac{cos^2 x}{sin^2 x}= \frac{sin^2 x}{sin^2 x+ cos^2 x}= sin^2 x<br /> since sin<sup>2</sup> x+ cos<sup>2</sup> x= 1.<br /> <br /> I&#039;m a bit puzzled by &quot;Given a right angled triangle&quot;. That seems to me to imply that the equation is true only if x is an angle in a right triangle but in fact that is an identity, true for all x.
Why do you mean by sketching a cubic?
You can get the answer directly from Pseudo's last step with no calculations.
Heard of the wavy curve method ?
No, I must say I haven't. What's the wavy curve method (sounds like something a hairdresser might use :smile:)?
That's new to me. What is it? I'm intrigued now :smile:
~H
Well, its just a silly name given to a simple method of solving such equations in math (I guess it was coined by some Indian as I see it only in Indian texts).You have probably learned it under some other name or no name perhaps.
Anyway,
If you have a polynomial function like (ax+b)(cx+d)... ,
and would like to know where the function is +ve or -ve( on the real line of course) just arrange the roots in ascending order as on the no line.
Start from the rightmost root.All values of the function for x greater than this root are +ve.Then in the interval between the largest and second largest the value is -ve and its goes on alternating between the roots.
As an example , in the above case x(3x+1)(3x-1),
The roots are -1/3,0,1/3.
x > 1/3 => expression +ve
0< x < 1/3 => -ve
-1/3< x < 0 =>+ve
x<-1/3 => -ve
Sounds familiar ?
Its called wavy curve because you can draw something of a wiggling worm on the no line.
HAHAHA
Anyway,
0< x < 1/3 => -ve
-1/3< x < 0 =>+ve
x<-1/3 => -ve
Sounds familiar ?
HAHAHA
But that's *exactly* the same as roughly sketching the curve to show the roots!:confused:
Also, don't forget that this method only forms the correct conclusions when the coefficient of the highest power of x is positive. If it's negative, the rule should be reversed for everything.
I'm sorry, this just doesn't strike me as anything to write home about, it's basically the same thing I do when I sketch the curve.:smile:
Sketching a curve or wavy curve its the same thing.
Just a little misunderstanding there.
And yeah I forgot about the coefficients.
Cheers,
Arun
Yes it is!
Suppose you have in general a cubic function f(x), you can sketch the curve to get a fair idea of the location of roots (using f&#039;(x) which is a quadratic and easy to solve). You can also use negative Rolle's Theorem if its applicable.
As a simple example, if you have something like x^2 &lt; 9 (this is too easy), you can write it as
(x-3)(x+3) &lt; 0
draw a rough number axis divided into 3 parts: x &lt; -3, -3&lt;x&lt;3 and x &gt; 3. Write down the sign of the function x^2 - 9 = (x-3)(x+3) in each of these regions. It is clear that the inequality is satisfied for -3&lt;x&lt;3. You can try doing this for cubic functions factorizable as 3 linear functions or a quadratic with complex factors and a linear factor. More examples will help...
  • · Replies 27 ·
  • · Replies 40 ·
9K
  • · Replies 22 ·
