Delete 'F', 'E', 'V' from 2-3 Tree
  • Thread starter Thread starter ooohffff
    trees
The discussion focuses on the process of deleting nodes 'F', 'E', and 'V' from a 2-3 tree in a specified order. Participants express uncertainty about the correct deletion method, particularly for node 'V', which has no children, suggesting it can be removed directly. The algorithm mentioned involves replacing a target with the largest item from its left subtree if it has children. There is a request for clarification on how to handle the deletion of 'E' specifically. The conversation emphasizes understanding the deletion process in 2-3 trees.
ooohffff
(P)
(F) (U)
(D, E) (J, O) (T) (V)
Given the 2-3 tree, delete F E V from the tree in the given order. Show the tree after each deletion.
Min = 1
Max = 2
Remove 'V' : Not sure what to do here
Am I doing this correctly? The algorithm in my book says to replace the target at data(i) with the largest item in subset(i) (rightmost child of left subtree), if I found the target at a node.
Hi,
How about just removing the 'V' node ? It has no subsets, so nothing replaces it.
Can you explain how you remove 'E' ?
