2 dimensional plane of a 3 dimensional space
  • Thread starter Thread starter Gear300
    Plane Space
In a 3-dimensional space, the projection operator onto a 2-dimensional subspace acts as an identity operator for that subspace, confirming that the identity operator is also applicable. The projection operator is generally unique, as it is defined by its image. However, it was clarified that the projection is not uniquely determined solely by the image due to the existence of complementary subspaces. This distinction highlights the complexity of projection operators in linear algebra. The discussion emphasizes the need for careful consideration of definitions in mathematical contexts.
Gear300
For a subspace of Rn, such as a 2 dimensional plane of a 3 dimensional space, wouldn't the projection operator onto the subspace act as an identity operator for that subspace, while at the same time, (I) would also be a (trivial) identity operator?
Furthermore, is a projection operator for a subspace unique?
Mathematics news on Phys.org
Yes, by the definition of projection operator, it's an identity on its image. Undoubtedly, I is also an identity on this subspace.
[STRIKE]Yes, a projection operator is uniquely determined by its image. It follows (easily) from the definition as well.[/STRIKE]
Hope that helps. Should you need proofs, just say.
Thanks for the reply. Before asking, I'll give the proofs a try.
I apologise, the projection is NOT uniquely determined by the image, because complementary subspace is not. Sorry if I wasted your time
:blushing:
Suppose ,instead of the usual x,y coordinate system with an I basis vector along the x -axis and a corresponding j basis vector along the y-axis we instead have a different pair of basis vectors ,call them e and f along their respective axes. I have seen that this is an important subject in maths My question is what physical applications does such a model apply to? I am asking here because I have devoted quite a lot of time in the past to understanding convectors and the dual...
Insights auto threads is broken atm, so I'm manually creating these for new Insight articles. In Dirac’s Principles of Quantum Mechanics published in 1930 he introduced a “convenient notation” he referred to as a “delta function” which he treated as a continuum analog to the discrete Kronecker delta. The Kronecker delta is simply the indexed components of the identity operator in matrix algebra Source: https://www.physicsforums.com/insights/what-exactly-is-diracs-delta-function/ by...
