2 lights with unequal brightness
  • Thread starter Thread starter jubbly
    Brightness Lights
To achieve unequal brightness in two lights connected in parallel, a resistor can be added in series with one of the lights. This will limit the current flowing through that light, resulting in lower brightness compared to the other light. The unique characteristics of parallel circuits allow each light to receive the same voltage, but the resistor alters the current distribution. Understanding the flow of current and voltage in parallel circuits is crucial for this setup. This approach effectively demonstrates the principles of electrical circuits in a practical project.
jubbly
For my physics house project, it says i have to have 2 lights connected in parallel with one switch and unequal brightness, using a resistor. Is there anyway to do this?
Science news on Phys.org
Well, what is it about parallel circuits that would make it work that way? Think about the way current and voltage flow through a parallel circuit. What makes a parallel circuit different in these regards compared to a series circuit? (I can't just answer this because it is a homework question, but I can try to help you!)
Thread 'A quartet of epi-illumination methods'
Well, it took almost 20 years (!!!), but I finally obtained a set of epi-phase microscope objectives (Zeiss). The principles of epi-phase contrast is nearly identical to transillumination phase contrast, but the phase ring is a 1/8 wave retarder rather than a 1/4 wave retarder (because with epi-illumination, the light passes through the ring twice). This method was popular only for a very short period of time before epi-DIC (differential interference contrast) became widely available. So...
I am currently undertaking a research internship where I am modelling the heating of silicon wafers with a 515 nm femtosecond laser. In order to increase the absorption of the laser into the oxide layer on top of the wafer it was suggested we use gold nanoparticles. I was tasked with modelling the optical properties of a 5nm gold nanoparticle, in particular the absorption cross section, using COMSOL Multiphysics. My model seems to be getting correct values for the absorption coefficient and...
