MHB *2 values of x for perpendicular vectors
The discussion centers on finding the values of x for which the vectors (2x/(x-3)) and ((x+1)/5) are perpendicular. The quadratic equation derived is 2x^2 + 7x - 15, yielding potential solutions of x = -5 and x = 3/2. Initially, there was confusion regarding the validity of x = 3/2, as it seemed not to produce perpendicular slopes. However, upon further examination, the error was identified, confirming that both values are indeed correct. The conversation highlights the importance of careful calculation in vector analysis.
karush
MHB
The vectors $$\left(\frac{2x}{x-3}\right)$$ and $$\left(\frac{x+1}{5}\right)$$ are $$\perp$$ for $$2$$ values of $$x $$
what is the quadratic equation which the 2 values of x satisfy
well I got $$2x^2+7x-15$$ which gives $$x=-5$$ and $$x=\frac{3}{2}$$
-5 seems to work but
$$\frac{3}{2}$$ doesn't or is there another way to do this.
thanks ahead,
Mathematics news on Phys.org
Re: 2 values of x for perpendicular vectors
thanks ahead,
Hi karush! :)
What is the reason you think $x=\frac 3 2$ does not work?
It is a proper solution.
when I plugged $$\frac{3}{2}$$ in the slopes didn't seem $$\perp$$
Well... which vectors do you get if you plug it in?
OK found my error...
Suppose ,instead of the usual x,y coordinate system with an I basis vector along the x -axis and a corresponding j basis vector along the y-axis we instead have a different pair of basis vectors ,call them e and f along their respective axes. I have seen that this is an important subject in maths My question is what physical applications does such a model apply to? I am asking here because I have devoted quite a lot of time in the past to understanding convectors and the dual...
Insights auto threads is broken atm, so I'm manually creating these for new Insight articles. In Dirac’s Principles of Quantum Mechanics published in 1930 he introduced a “convenient notation” he referred to as a “delta function” which he treated as a continuum analog to the discrete Kronecker delta. The Kronecker delta is simply the indexed components of the identity operator in matrix algebra Source: https://www.physicsforums.com/insights/what-exactly-is-diracs-delta-function/ by...
