Can the principle of rebound be applied to air molecules impacting a surface?
The discussion explores whether the principle of rebound, observed in macroscopic objects like rubber balls, can be applied to air molecules impacting surfaces. It explains that when a rubber ball hits a surface, it compresses and stores kinetic energy as potential elastic energy, which is released during rebound. The conversation suggests that air molecules also experience a similar energy exchange upon impact, but potential energy is primarily stored at the moment of impact rather than in a sustained form. The analogy extends to the behavior of air molecules, where their energy is largely kinetic, and any potential energy is linked to their height in a gravitational field. Ultimately, the mechanics of rebound at the microscopic level differ due to the inability to compress molecules beyond their inherent state.
slowbutsteady
Hi, so glad to be here. This is my first posting. I'm just a 61 year-old dummy, so please help!
If a rubber ball is dropped to a hard surface the impact will compress the rubber, storing some of the kinetic energy as potential elastic energy. The rebound will come from this stored potential elastic energy. If the ball is dropped straight down I presume this elastic force is stored in the ball mostly in an axis normal to the ground, ie. the ball is smushed out making it just a little fatter at its' "equater" than at its' poles (the axis of impact).
If I've got this bouncing ball thing right so far, can this idea of storing potential energy mostly along the axis of impact be carried over to air molecules? Do air molecules impacting a surface, like the walls of a containing vessel, hold potential energy (for the rebound) mostly in the axis of impact (normal to the impact surface)?
Let's change the world...does anybody out there know the answer?
Thank you in advance!
If a ball rebounds from the ground perfectly (ie. rebounds to the same height from which it was dropped), then all the energy of ball is completely kinetic just before and just after it hits the ground. The point at which it hits the ground is complex, and perhaps potential energy is stored in the material of the ball for a very short time. So if there is potential energy stored in the material of the ball, it is only at the point of impact.
Just after impact, the energy of a perfectly rebounding ball entirely kinetic. As it rises in height, the kinetic energy is converted to potential energy - but this potential energy is not stored in the material of the ball, it is stored in the ball by virtue of its height in the gravitational field.
So it's the same for an air molecule, any potential energy stored by "compressing" it occurs only at the point of impact with the walls of the container or with other air molecules. It's a good first approximation to think of the energy of air as entirely kinetic. A tall column of air has potential energy, but again, that's just because things held high above the ground have gravitational potential energy.
Actually, it's not clear that the smushing (away from the axis of impact) of the material at the point of impact aids a perfect rebound. If the compression occurs in the wrong way, then some of the kinetic energy of the ball is converted into heat, so the ball will rebound to a lesser height, but will feel slightly warmer after the rebound. Heat is the vibration of the material of the ball in random directions, so for there to be no loss of energy as heat, you are right that the compression should be along the axis of impact.
Another way to get a perfect rebound is to make the ball of material so hard that it cannot have any internal compressions or vibrations at all, so it can never be heated up. You should also make the ball very small, because internal rotations will take away from the rebound. If you use a perfectly hard material for your ball, you still may not get the perfect rebound, because the ground must also be perfectly hard for that to work. So this is very impractical, and I think only theorists use such prefectly rebounding balls.
A better analogy might be the fully elastic interation of two opposing magnets approaching each other on a firctionless surface. They will not physically collide, but there will be a collision like reaction, with preservation of momentum and of kinetic energy. Even without a collision, the opposing forces will result in a compression at the inner surfaces of the two magnets.
Regarding the relastionship between speed and temperature:
http://en.wikipedia.org/wiki/Equipartition_theorem
There's a really neat mathematical equation based on a theorem called
the "equipartition theorem" which states that the energy of a gas system
(equal to 1/2*mv^2) is equal to the temperature of the gas (equal to 3/2*kT).
If we rewrite this equation to solve for velocity we get:
sqrt(3*T*k/m) = v
where T is the temperature in Kelvin, k is the Boltzman constant = 1.3805*10^-
23 J/K and m is the mass of the gas particle.
If we assume that the average mass of air (since it is a mixture of different
gases) is 28.9 g/mol (or each gas particle is around 4.799*10^-26), and room-
temperature is 27C or 300K, we find that the average velocity of a single air
particle is around 500 m/s or 1100 miles per hour!
http://www.Newton.dep.anl.gov/askasci/chem03/chem03448.htm
Note that this average speed of air molecule is much faster than the speed of sound
at a specific temperature, since the speed of sound is based on the speed of propgation
of collisions, instead of the speed of the molecules. At 27C, the speed of sound in
the air is 347 mps or 777mph.
slowbutsteady said:
Do air molecules impacting a surface hold potential energy (for the rebound) mostly in the axis of impact (normal to the impact surface)?
If i have understood your question you are trying to apply the mechanism of rebound you have just analyzed at macroscopic scale to a microscopic scale, for example air molecule instead of a rubber ball. I think the main difference for microscopic object, such as molecule, atom or particle, is that you cannot always speak of "compression" because it may happens that the object dosent allow any state "more compressed" that one in which is. However the mechanism is similar: you have exchange of energy from kinetic to an interaction's potential and then release.
Ll.
Consider an extremely long and perfectly calibrated scale. A car with a mass of 1000 kg is placed on it, and the scale registers this weight accurately. Now, suppose the car begins to move, reaching very high speeds. Neglecting air resistance and rolling friction, if the car attains, for example, a velocity of 500 km/h, will the scale still indicate a weight corresponding to 1000 kg, or will the measured value decrease as a result of the motion? In a second scenario, imagine a person with a...
Thread 'Gauss' law seems to imply instantaneous electric field propagation'
Imagine a charged sphere at the origin connected through an open switch to a vertical grounded wire. We wish to find an expression for the horizontal component of the electric field at a distance ##\mathbf{r}## from the sphere as it discharges. By using the Lorenz gauge condition: $$\nabla \cdot \mathbf{A} + \frac{1}{c^2}\frac{\partial \phi}{\partial t}=0\tag{1}$$ we find the following retarded solutions to the Maxwell equations If we assume that...
Dear all, in an encounter of an infamous claim by Gerlich and Tscheuschner that the Greenhouse effect is inconsistent with the 2nd law of thermodynamics I came to a simple thought experiment which I wanted to share with you to check my understanding and brush up my knowledge. The thought experiment I tried to calculate through is as follows. I have a sphere (1) with radius ##r##, acting like a black body at a temperature of exactly ##T_1 = 500 K##. With Stefan-Boltzmann you can calculate...
