Distance-Time Graphs: Negative Gradient Explained
  • Thread starter Thread starter KellyOsbourne
    Graphs
Distance-time graphs cannot have a negative gradient because distance is a scalar quantity, meaning speed is always non-negative. In contrast, position-time graphs can show a negative gradient, which indicates negative velocity as they represent displacement, a vector quantity. The confusion arises from misinterpreting distance-time graphs as position-time graphs, where the latter can depict movement back towards the starting point. The graph referenced in the discussion was deemed incorrect for suggesting negative speed. Understanding the distinction between distance and displacement is crucial for interpreting these graphs accurately.
KellyOsbourne
I was told by my teacher that the definition for distance is just "the amount of ground covered", and that displacement is "the distance in a particular direction". I was looking at some distance-time graphs online and I saw that towards the later stage of the journey in some of the graphs, the gradient of the distance-time graph was negative. Their explanation for the negative gradient was that the object was moving towards the starting position. I do not understand that. Even if the object is moving towards the starting position, it is still covering "ground" and it would go up, right? And the gradient of a distance-time graph is the speed, and I didn't think there was anything called negative speed. I know about negative velocity, but negative speed? Please clear this for me! I want to know how the gradient of a distance-time graph can be negative, when distance is just the "ground" covered.
This could be a very stupid question :$ But I am sometimes very blind to the obvious. Please help! :)
Thank you a lot in advance!
Welcome to Physics Forums.
I distance-time graph cannot have a negative gradient, since as you say distance (and hence speed) is a scalar quantity. However, a position/displacement time graph can have a negative gradient since position/displacement is a vector quantity.
On a distance-time graph the gradient represents the speed, which is always non-negative. However, on a position-time graph, the gradient represents the velocity, which can be negative.
Could you provide a link to the graphs with the negative gradient, I have a sneaking suspicion that they are position-time graphs.
Thank you so much! Yes, that's what I thought :)
Here is the link:
http://www.golfranger.co.uk/speed.html
Please tell me if I made a mistake in interpreting whether it was a distance-time graph or a displacement-time graph, and how I can distinguish between the two.
Again, thanks so much :)
Here is the link:
The graph shown on that page is clearly incorrect. The negative gradient of the red curve indicates a negative speed, which is impossible.
Is your school hosting this website?
Thank you, I thought I was going bonkers!
Umm, no, my school's not hosting it. I just ran across it when I was looking for information to prepare a poster for school.
Thread 'Gauss' law seems to imply instantaneous electric field propagation'
Imagine a charged sphere at the origin connected through an open switch to a vertical grounded wire. We wish to find an expression for the horizontal component of the electric field at a distance ##\mathbf{r}## from the sphere as it discharges. By using the Lorenz gauge condition: $$\nabla \cdot \mathbf{A} + \frac{1}{c^2}\frac{\partial \phi}{\partial t}=0\tag{1}$$ we find the following retarded solutions to the Maxwell equations If we assume that...
Maxwell’s equations imply the following wave equation for the electric field $$\nabla^2\mathbf{E}-\frac{1}{c^2}\frac{\partial^2\mathbf{E}}{\partial t^2} = \frac{1}{\varepsilon_0}\nabla\rho+\mu_0\frac{\partial\mathbf J}{\partial t}.\tag{1}$$ I wonder if eqn.##(1)## can be split into the following transverse part $$\nabla^2\mathbf{E}_T-\frac{1}{c^2}\frac{\partial^2\mathbf{E}_T}{\partial t^2} = \mu_0\frac{\partial\mathbf{J}_T}{\partial t}\tag{2}$$ and longitudinal part...
Thread 'A scenario of non uniform circular motion'
(All the needed diagrams are posted below) My friend came up with the following scenario. Imagine a fixed point and a perfectly rigid rod of a certain length extending radially outwards from this fixed point(it is attached to the fixed point). To the free end of the fixed rod, an object is present and it is capable of changing it's speed(by thruster say or any convenient method. And ignore any resistance). It starts with a certain speed but say it's speed continuously increases as it goes...
