I 2as = v^2 an other equations dealing with the past
  • I
  • Thread starter Thread starter spino
spino
2as = v^2 but why do they have the formula 2as = v^2-vo^2 displayed as correct without a reference that its wrong. In Basic physics classes it may not even be mentioned that its wrong. I understand that no one is teaching relativistic physics but why not even mention it. Its been over a 100 years and its still being used in physics books today as being correct along with other formulae dealing with the past.
https://chem.tufts.edu/answersinscience/relativityofwrong.htm
What is your question? Newton's physics is good enough to cover most of all real world problems. As it is easier, it doesn't make sense to calculate the movement of a car relativistic. It's not measurable.
It will be mentioned where it is relevant.
If you meant the difference of the term ##v_0##, then this is the difference whether there is an initial velocity before acceleration starts or not. Both are valid for certain cases.
It is still being used because it is still correct within its domain of applicability, as shown by a mountain of experimental evidence.
Edit: actually, the suvat equations are exactly correct, even in relativity.
OK, so this has bugged me for a while about the equivalence principle and the black hole information paradox. If black holes "evaporate" via Hawking radiation, then they cannot exist forever. So, from my external perspective, watching the person fall in, they slow down, freeze, and redshift to "nothing," but never cross the event horizon. Does the equivalence principle say my perspective is valid? If it does, is it possible that that person really never crossed the event horizon? The...
ASSUMPTIONS 1. Two identical clocks A and B in the same inertial frame are stationary relative to each other a fixed distance L apart. Time passes at the same rate for both. 2. Both clocks are able to send/receive light signals and to write/read the send/receive times into signals. 3. The speed of light is anisotropic. METHOD 1. At time t[A1] and time t[B1], clock A sends a light signal to clock B. The clock B time is unknown to A. 2. Clock B receives the signal from A at time t[B2] and...
From $$0 = \delta(g^{\alpha\mu}g_{\mu\nu}) = g^{\alpha\mu} \delta g_{\mu\nu} + g_{\mu\nu} \delta g^{\alpha\mu}$$ we have $$g^{\alpha\mu} \delta g_{\mu\nu} = -g_{\mu\nu} \delta g^{\alpha\mu} \,\, . $$ Multiply both sides by ##g_{\alpha\beta}## to get $$\delta g_{\beta\nu} = -g_{\alpha\beta} g_{\mu\nu} \delta g^{\alpha\mu} \qquad(*)$$ (This is Dirac's eq. (26.9) in "GTR".) On the other hand, the variation ##\delta g^{\alpha\mu} = \bar{g}^{\alpha\mu} - g^{\alpha\mu}## should be a tensor...
