Identifying Multiple Oscillations in a Graph
The discussion centers on the dynamics of two masses (M1 and M2) connected by three springs with constants k1, k2, and k3. The forces acting on the blocks are defined by the equations F1 = -k1(x1) + k2(x2 - x1) and F2 = -k2(x2 - x1) - k3(x2). The angular frequency of the system is approximately 15.8 rad/s, but discrepancies arise when simulating the system in MATLAB, yielding a frequency of around 22 rad/s. The conversation highlights the importance of initial conditions and the potential for multiple oscillation modes affecting the observed frequencies.
  • Understanding of Newton's laws of motion
  • Familiarity with spring constants and Hooke's Law
  • Knowledge of angular frequency in oscillatory systems
  • Proficiency in MATLAB for simulating physical systems
  • Explore the derivation of equations of motion for coupled oscillators
  • Learn about the concept of normal modes in mechanical systems
  • Investigate the effects of initial conditions on oscillation frequencies
  • Practice simulating coupled spring-mass systems in MATLAB
Physics students, mechanical engineers, and anyone interested in the dynamics of oscillatory systems and coupled oscillators.
GoCubs12
Two masses (M1 and M2) are connected together by 3 springs. The spring constants are k1, k2, k3. Block 1 is at equilibrium at x=0. Block 2 is at equilibrium at x=1. Determine a function for the force on the blocks.
[/B]
Without using the initial values, I was able to get the following equations
F1=-k1(x1)+k2(x2-x1)
F2=-k2(x2-x1)-k3(x2)
I looked around the internet and believe these equations are correct, however, my problem is converting them to work with the initial values in the problem. At equilibrium, the force on block 1 is 0 and x1 is 0. Using this I got the equation
F1=-x1(k1+k2)
Doing the same procedure with block 2 where its equilibrium is at 1, I got the following
x1=(k3/k2)+1
so...
F2= -k3(x2)-k2(x2-((k3/k2)+1)
I know the angular frequency of the blocks is about 15.8 rad/s. However, when these equations are used in a program to model the motion of the blocks, the frequency is around 22. I know the program is correct, and so the equations must be wrong, but I have no idea how.
Thanks in advance for the help!
How are the springs arranged? In series? Parallel? (A diagram would be helpful.)
Spring 1 is attached to the left side of block1. Then spring 2 connects the right side of 1 and left the side of 2 together. Then spring 3 goes from the right side of block 2 to another wall. I tried to type out the diagram below.
Wall k1 block 1 k2 block 2 k3 wall
If x1 is the position of block 1, x2 the position of block 2, express the force from each spring in terms of its displacement from equilibrium.
The force from spring 1 is easy since the unstretched position is at x = 0. So it's -k1x1.
When block 2 is at position x2, how much is spring 3 stretched? And then do the same for spring 2.
For spring 3, I got (1-x2) for its displacement
For spring 2, I got (x2-x1)
These still don't seem to be right though
OK. I'd express it as x2-1. When x2 > 1, the spring is compressed.
This won't work. At equilibrium, when x2 = 1 and x1 = 0, the amount the spring is stretched is 0, not x2-x1 = 1. Try again.
Note that for simplicity I assume that at equilibrium all springs are at their unstretched length. But that doesn't really matter. The resulting equations will be the same even if you assume some non-zero initial tension, since they are at equilibrium.
Doc Al said:
OK. I'd express it as x2-1. When x2 > 1, the spring is compressed.This won't work. At equilibrium, when x2 = 1 and x1 = 0, the amount the spring is stretched is 0, not x2-x1 = 1. Try again.
Thanks for the help. So for spring 2 it should be 1-x2-x1?
Almost. The difference in position is x2-x1. When that differs from 1, the spring is stretched or compressed. I'd write that as (x2-x1)-1.
Okay. So the force on block 1 would be the force from spring 1 and 2.
so... F1=-k1(x1)+(x2-x1-1)k2
and the force on block 2 would be
F2= -k3(x2-1)-(x2-x1-1)K2I tried these equations and they produce the correct angular frequency if both blocks are initially put at 0.25m to the right of their equilibrium positions. However, the frequency is different if one is put -0.25 from its eq. position. Should this be the case? I thought no matter where they start they should always have the same angular frequency as its value is not dependent on the starting positions of the blocks.
I agree. The frequency of oscillation should not depend on initial positions.
I assume you mean that with both blocks so positioned the system is at equilibrium.
Please post your working.
So using the forces of motion above I get the following graphs. When x1 is put at an initial position of 0.25 and x2 is at 1.25, the first graph is obtained. When x1 is at -0.25 and x2 is at 1.25, the second graph is obtained. Both times the masses are either in phase or antiphase, which is what I expect, however, the second starting position the period is much faster and I am at a loss to explain it. The first period seems to be what would be expected. I also can't seem to find a way to upload an image of these graphs.
How are you creating these graphs - by simulation using the differential equations or by solving them?
haruspex said:
How are you creating these graphs - by simulation?
Yes using MATLAB
haruspex said:
It is feasible that there are two different modes of oscillation at different frequencies, and that in general these would be superimposed. Different initial conditions could change their relative amplitudes.
Good point!
GoCubs12 said:
Could you explain what that means?
As shown at the link I posted, the equations have two solutions for the frequency. In general, both frequencies occur, superimposed. I.e. the displacement of a given mass will be ##A_1\cos(\omega_1t+\phi_1)+A_2\cos(\omega_2t+\phi_2)##. The other mass will have different amplitudes and phases, but the same frequencies.
The values of the phases and amplitudes will depend on the initial conditions. It may be that in one of the two cases you tried one of the two oscillations dominated, and in the other case the other dominated.
Play around with the initial conditions to see if you can observe a case where both oscillations are clearly present.
How would I know when both oscillations are present?
It should be quite clear in the graph. Use Matlab with a sum of two cosine functions, different frequencies but not multiples of each other, similar but different amplitudes. Phase won't matter.
12K
14K
